Old 08-04-2010, 05:58 PM
antsals is on a distinguished road
ABB Inverter Drive and Motor Setup
Help,
I've just purchased a new inverter drive and motor kit from Inverter Drive Supermarket online.
http://www.inverterdrive.com/group/A...1/default.aspx
I have the inverter drive and motor wired up but am concerned around setting the unit up. I've set the parameters as below:-
I followed the instructions pg 39 – 43.
• 9902 - Application Macro – 1
• 9905 – Motor Nominal Voltage – 230v
• 9906 – Motor Nominal Current – 1.5 Amp
• 9907 – Motor Nominal Frequency – 50.0Hz
• 1105 – Max Value for External Reference – 50.0Hz
• 1202 – Constant Speeds (Drive Output Frequencies) – 5.0Hz
• 1203 – Constant Speeds (Drive Output Frequencies) – 10.0Hz
• 1204 – Constant Speeds (Drive Output Frequencies) – 15.0Hz
• 1301 – Set Min % Value corresponding to minimum signal for AI(1) – 0.0%
• 2008 – Maximum drive limit output frequency – 50.0Hz
• 2102 – Motor Stop Function – 1
• 2202 – Acceleration time – 5 Secs
• 2203 – Deceleration time – 5 Secs
Not sure this is setup correctly.......then I want to integrate into a CNC controller, CNC2x from EaziCNC.
http://www.eaziform.co.uk/index.php?products,cnc2x
Just looking for a little help / guidance?
Cheers
Ant
Old 08-04-2010, 06:02 PM
Just a few pics of the kit.
Ant
ID:	112202   Click image for larger version
ID:	112203   Click image for larger version
ID:	112204   Click image for larger version
ID:	112206   Click image for larger version
Problem- Mitsu. inverter motor cont. ? rockmup Mazak, Mitsubishi, Mazatrol 3 01-25-2010 07:59 AM
NEW Baldor 2hp Inverter-Duty 145TC motor Zumba EBAY ADS 0 07-27-2009 11:57 PM
Need Help!- 1981 GE Inverter drive / Cincinnati Milacron Hydrotel Cronicstorm General Electronics Discussion 0 09-19-2008 06:32 PM
Inverter setup multex1 Phase Converters and VFD 3 08-24-2007 09:56 PM
Discovery 300 inverter drive problems tenmetalman Bridgeport and Hardinge Mills 3 04-07-2006 04:19 PM
