Do the calculations for 25 amps and you'll be okay. The 750VA one will work fine, the 1000VA will give you alot of room for growth. Transformer voltage what you've calculated is correct, using a bridge add another 1.4 volts for 2 diode drops...does Plitron offer custom voltages? If not then pick something between 28 and 30 VAC.
LinkBack URL
About LinkBacks
