Hi everyone, I was wondering if anyone knew anything about a 'Burgess CR1D2' micro switch (datasheets etc.)??? I asked my Dad to have a look at work to see if they had any old limit switches for my machine, and sure enough, he came home with 6 of these Burgess units. I can't find any specs on the net about them, except a couple of places that have/had them for sale. At £33 each, I think I got quite a bargain. The six switches are almost worth more than the machine... Here's one link I found: http://tait.greystone.co.uk/ProductD...itches&iPage=1 Any thoughts on specs etc??? Thanks Warren
__________________ Have a nice day... |
| Wow, I've never seen any as expensive as that, about Can$50.00, they are a typical micro-switch knock-off or equivalent, they can often be picked up by the box on ebay for a few dollars. They are just Normally-open, Normally-closed contact single pole, probabally around 5amp resistive load. Al.
| yea, use pin 1 and 3 for normally open use in 1 and 2 for normally closed its printed on the side, the numbers should be by the respective contacts on the bottom. if not, it should be easy to figure out with a continuity tester ie. lightbulb, battery, and wire
__________________ --- router finally being built! y axis done! hobbycnc controller done! ...mounting nsk rails and thk rail. aligning leadscrews |
| Help with limit switches and Xylotex board | dowling177 | Xylotex | 5 | 11-26-2008 02:51 PM |
| Limit switches | itsme | General Electronics Discussion | 5 | 05-01-2005 05:02 PM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 01:28 PM |
| Limit switches and home switches | viktorcnc | TurboCNC | 2 | 08-03-2004 06:11 AM |
| Home switches and limit switches. | ynneb | General Electronics Discussion | 5 | 04-08-2004 05:32 PM |
