Old 07-25-2010, 01:41 AM
Apples's Avatar
Apples is on a distinguished road
Can I buy brackets to mount parts in my electrical enclosure?
So this is the case I will be using to mount a power supply, bob and drivers etc. There is on the left and right hand sides slots for mounting brackets etc.
I don't want to have to drill through the bottom of the case to have to mount the parts etc. So what is the best way to do it? Surely there must be brackets you can buy to do what I want to do. Or do you just bend up some tin youself?
Peter
Name:	Control Enclosure.JPG‎
My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
Old 07-25-2010, 07:41 AM
vger's Avatar
vger is on a distinguished road
Unless the maker of that cabinet has mount parts specificly for that one, you will probably have to fashion your own. You might try a hardware store in your area for some aluminum angle stock. Maybe some 10 X 10 X 2 (mm) angle stock to make some rails to go from one side to the other secured to the slotted holes to mount your parts on.
Steve
Old 07-25-2010, 08:06 AM
TOTALLYRC is on a distinguished road
The way pro boxes do it is that they have a removable back plate and all the stuff mounts to the back plate. The back plate mounts via standoffs.
You could fab up some brackets from the slots to hold a back plate. You will be surprised how much prewiring you can do before you put the plate with all the stuff on it into the case.
Mike
Old 07-25-2010, 04:08 PM
ViperTX is on a distinguished road
You can also use standoffs. I have also used L-shaped brackets from home improvement stores....I usually buy the solid brass ones as they are easier to cut and drill.
Paul
Old 07-26-2010, 12:17 PM
gpraceman is on a distinguished road
On my power supply, I just used the existing mounting holes on the bottom. There are also mounting holes on the sides.
For the BOB, it probably has holes that you can mount it to standoffs and then secure the standoffs to the enclosure.
Old 07-26-2010, 05:28 PM
Apples's Avatar
I'm now thinking I might just bend up a bit of sheet steel so that it bolts to the sides in that case and just have it so it's about 1/4" off the bottom.
Then I can just bolt and screw everything down onto the one piece.
Old 07-27-2010, 02:32 PM
sportybob is on a distinguished road
If you are looking to mount contactors, power suply, etc most commercial products are made to mount to " DIN rails. The rails can be mounted to a back panel that can mount inside your enclosure. Or you can mount directly to the inside.
here is one source for the din rails. Google for others.
http://www1.mscdirect.com/Din-Rail/E...002003146.HTML
Temp rise in an electrical enclosure garagefela General Electronics Discussion 10 10-04-2009 08:21 PM
Electrical Enclosure and Wiring.. HELP! firestorm1284 Benchtop Machines 15 03-04-2009 12:01 PM
Electrical/Electronics Enclosure audioandy1762 DIY-CNC Router Table Machines 0 02-27-2007 06:32 AM
need some electrical parts for BP series 1 zoqdi Bridgeport and Hardinge Mills 1 02-07-2007 03:18 PM
RFQ, water-jet type parts, 4" alum. brackets sswitaj Employment Opportunity 4 09-04-2006 09:09 PM
