Old 07-12-2010, 08:28 AM
bluechipmfgllc is on a distinguished road
Mazak Nexus 200 - Battery Malfunction Alarm
We got a #379 Battery Malfunction Alarm (TAIL)
According to the manual it says to replace the battery, but we have no idea where the battery is located at. it is a Mazak Nexus 200
Any help??
Old 09-27-2011, 09:58 PM
atothek80 is on a distinguished road
mazak battery issue
I can see by the date that this is old but i thought I'd answer anyway for someone else who is looking for the answer. If you open up the electrical panel on the back there are some little boxes with red led displays on them one will be flashing al for alarm. Pull off the cover and there will be a Mitsubishi battery that you need to replace. Remember if you turn off the machine some parameters may end up needing reset so order your battery and leave it on until you have finished installing the new one.
Need Help!- Mazak T32-3 Alarm 015 System Malfunction reillyeng Mazak, Mitsubishi, Mazatrol 8 05-27-2011 08:24 AM
Mazak nexus 250 cadcamsolutions Mazak, Mitsubishi, Mazatrol 2 09-11-2009 02:20 PM
Mazak Nexus 510 jamie pinols General Metal Working Machines 3 08-20-2009 11:19 PM
post for mazak 640 m Nexus with Pro-E plast-art Mazak, Mitsubishi, Mazatrol 4 01-01-2009 03:29 PM
Mazak VTC-160 A servo malfunction sting_dot Mazak, Mitsubishi, Mazatrol 3 05-21-2007 11:19 PM
