Old 07-10-2010, 01:24 PM
yosko is on a distinguished road
Difference in output for AC/DC converter
Have two AC to DC converters/battery chargers and one has output of 19.5V 3.34A and other has output of 19.5V 4.62A. What is the difference between them regarding the amp portion of output if the output volts are the same? Would one just charge the battery faster?
Old 07-10-2010, 01:44 PM
Al_The_Man's Avatar
If the current capability is higher, yes it is capable of charging faster, many battery chargers now are a bit more than the simple transformer & rectifier of years ago, most have some kind of voltage sensing of the battery being charged.
If there is no regulation, as the battery charges it opposes the battery charger output and the current falls accordingly.
Some are designed with the higher voltage output in order to maintain a constant high charge current in order to effect a rapid charge.
VSD-E and VSD-XE difference LBodnar Granite Devices 6 02-28-2010 02:27 PM
Difference between CHANDRU Linear and Rotary Motion 1 02-17-2009 06:31 AM
Need Help!- Difference between 2D NC and 2.5D NC Pols General CAM Discussion 1 10-14-2008 07:30 AM
tach output converter keithmech General Electronics Discussion 0 10-14-2007 12:57 PM
What's the difference? saturnnights Knee Vertical Mills 10 05-04-2006 10:31 AM
