Old 05-29-2005, 04:20 AM
stuart76 is on a distinguished road
Smile Power supply calculations???
Hi guys, Im electroically illiterate so I was wondering if anyone could confirm or correct my thoughts.
Im building a 4 axis mini mill. I have 4 stepper motors (1.8 volts - 3 amps - 6wire). Ill be running 12 volts into the motors.
If 3 amp means 3 amps per phase then thats 6 amps per motor, times 4 motors so will i need a power supply that can supply more than 24 amps? (seems alot). Ive also been told to go for 1 power supply rater than multiple supplys due to common earth voltage variation??? Its alot cheaper to buy a few small amp supplys than 1 big one. thanks.
Old 05-29-2005, 06:59 AM
OCNC is on a distinguished road
I think the way you figure it in your example is 3 amps per motor as only one phase is active at any moment so that would give a requirement of 12 amps. Also less current is drawn with less loading so how close you will be to full load over what period of time becomes a factor. Linear power supplies can typically be overdrawn for short periods of time without being damaged. The intermittent collapsing back EMF of the steppers also adds to the conservation of power.
Chris
Old 05-31-2005, 02:16 AM
2muchstuff is on a distinguished road
If you are using a driver that has a pulse width modulated output (Gecko) your current usage will be 2/3 rds of your motors nameplate rating. This is due to the power going to the motor being pulsed.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 05-31-2005, 01:32 PM
H500 is on a distinguished road
Your power supply selection will depend on your choice of controllers. If it's one that uses power resistors to limit the current, then you do need 24 amps for 4 motors. Most controllers drive 2 coils simultaneously.
You should really avoid this type of drive since the power resistors and bigger power supply will end up costing as much as a chopper drive, which gives you much better performance.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Power supply calculations questions cnczoner General Electronics Discussion 0 05-31-2004 12:30 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
