Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: photomicro sensor, ~$25. Will this work for home switch?
    Nov 2004
    Lightbulb photomicro sensor, ~$25. Will this work for home switch?
    I found this in the MSC book O' goodies, and I was wondering if it would function as a home and limit switch with mach 2.
    Link: http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=1943178
    just in case, it is item # 54048061
    It seems to me I could place this on the undercarriage of my small gantry machine, with a small tab that would interupt the light when I am about 1" from the mechanical limits of my machine. I do have a 5v/12v power supply, but I am a blatant fool when it comes to this electrickery stuff.
    Would this switch give me better repeatability (as a home switch) than the standard mechanical microswitch?
    Thank you
    Rob
    Aug 2004
    Greece
    I think so. At least I'm going to try it because you can make it coolant-proof. If you enclose it in a watertight enclosure and have a rod sticking out (sealed with an O-ring) with a tab on the other side I think it would work better than a microswitch.
    Aug 2004
    The problem is that this will require some additional circuitry before you can sense whether it's on or off. The other problem is that the lens for the photodiode can become dirty if you're cutting anything that produces a bunch of dust....stick with a microswitch.
    Dec 2003
    At $22.00 that's damned expensive for a slotted photo detector, you can get Sharp and others for $1.50 (Digi-Key etc), you may have to add a 2n7000 to switch a relay etc, but if it is just TTL input and you you don't need indicator light etc, its a cheaper way to go.
    Al
    Nov 2004
    Thank you for your responses. I thought I was black listed for a week or two there...
    Maybe this info adresses the concerns brought up:
    Excerpt from MSC: Transmissive sensing heads in standard, L-shaped, T-shaped and close-mounting configurations match most applications. Wide 5-24 VDC operating voltage range makes these photomicrosensors compatible with TTLs, relays and programmable controllers. Wire selectable Light-ON/Dark-ON output operation. Operation indicator for easy monitoring. Output Specifications: 100 mA load with 0.8 V residual voltage; 40 mA load with 0.4 V residual voltage when driving TTL. Response frequency: 1kHz (3 kHz typical).
    Al, does this answer the concerns raised over this particular model?
    I bought a power supply from A. Duncan that puts out 5V to power the switch, can I then send the output of this sensor directly into my DB25 board?
    The design of my gantry router will keep the dust out of these well. Also, if it does get dusty, it will be wired so that the gantry stays on the machine (Dark-on).
    PS: 1. What kind of repeatability is everyone getting from their switches?
    e.g. 0.1", 0.01", 0.001", etc
    2. What kind of switch is it?
    3. What is the basic cost of that setup?
    Dec 2003
    It has a few built in features over a discrete opto-slot sensor, but these features could be added quite cheaply, the unit shown has some conditioning circuitry that probabally squares the signal up and has either TTL direct in or will operate a relay if required and has an indicator. The same could be put together for under $5.00
    (2) It is a infra-red transmitter/photo-sensor type detection switch.
    Al
    Gold Member
    Apr 2004
    have you considered using a prox switch? They don't care about contaminents (unless your cutting metal) and they are available with a very narrow sensing window that makes them very accurate. I have 9 of them on my machine and they work great.
    Chuck
    Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
    drk
    drk is offline
    Oct 2004
    india
    Chuck
    Just wanted to know what was the connection diagram for the prox. switches.
    Most I found were tooo large in size, expensive( $20) and work on 12V or more, while the cnc softwares used by hobbyist usually require a simple operation at 5V
    Banned
    Mar 2003
    I too think these are kind of expensive.
    Here's a link to a page full of choices of tabbed/untabbed, wide/narrow slot and a wide range of current draws - most are under $1.00.
    http://www.jameco.com/webapp/wcs/sto...egoryId=151050
    plm
    Nov 2004
    "have you considered using a prox switch? They don't care about contaminents (unless your cutting metal) and they are available with a very narrow sensing window that makes them very accurate. I have 9 of them on my machine and they work great.
    Chuck"
    How accurate/repeatable will these be? I would like to think it is possible to set my machine up such that it will "home" at a specific location, plus or minus 0.001" or less. Am I dreaming out loud on this?
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    I am using a 2-$5 microswitch and it zeros to within .0003-.0004 each time. Although for microswitches i think the wear/out factor is more of an issue. and if you want it sealed you have to make your own box. The optical switches or the prox switch are probably as good as the micro.
    The microswitch is definitely the cheaper rout. but backlash is my limiting factor.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Registered bkukowski's Avatar
    May 2005
    Illinois, USA
    is there already a schematic for using a prox switch or a photosensor posted somewhere?
  • Page 1 of 2 12 LastLast
    1. Solid-State limit switch experiment
      By Swede in forum General Electronics Discussion
      Last Post: 01-08-2010, 02:20 PM
    2. Would this work as a limit/home switch?
      By DAB_Design in forum General Electronics Discussion
      Last Post: 12-17-2004, 08:59 AM
    3. limit switch override
      By swarfmacdaddy in forum TurboCNC
      Last Post: 12-12-2004, 04:47 AM
    4. 5th even 6th axis? how does it work
      By ToMMY2ooo in forum General Metal Working Machines
      Last Post: 10-04-2004, 04:58 PM
    5. Work Holding Methods
      By InventIt in forum DIY CNC Router Table Machines
      Last Post: 09-14-2004, 04:13 AM
