Old 06-25-2010, 11:53 PM
helow is on a distinguished road
Running unipolar stepper motor with TIP120
hey
there are two circuits using same transistor but one of them do not have diodes. i read
bout these diodes as following:
"The diodes are a feature typical of circuits that handle magnetic coils, that is inductive
circuits. In this context, the motor windings are the inductive element. Capacitors provide
a means for the storage of electrical charge, inductors provide a means for storage of
electrical current. The driving current causes a magnetic field to be built up in the coil.
As soon as the drive is removed, the magnetic field collapses and causes the inductor to
release its stored current. Semiconductors are particularly sensitive to these currents
(they briefly become conductors and then become permanent nonconductors!). The diodes
provide a mechanism to safely shunt these currents away and, thus, protect the transistors
and the computer."
but in second circuit there is not diodes. why. how much important to use these diodes. if
not to use diodes then which are general measures to protect the transistors from being
burnt as described in above sentence.
and there are some detail about connections of wire:
"You should also note that ground for the transistors must be made common between the
parallel port (say at pin 25) and the motor power supply. An additional wire with an
alligator clip can be used to provide access to the ground for the motor power supply. So,
on the motor side of the circuit we have six wires, one for each coil, one for ground and
one for the motor voltage on the shunt diodes. The motor (positive) voltage supply is
provided through the common coils."
how the motor coil's conman wire and the four diodes wires will be used.
and also tell me about connection of motor with circuit which has not diodes.
http://www.forth.org/fd/Step.html
Old 06-26-2010, 03:04 PM
H500 is on a distinguished road
You have to use diodes or your transistors will be destroyed. A better approach is to use a FET. They have built in diodes.
Old 06-26-2010, 03:07 PM
LZ1TWB's Avatar
LZ1TWB is on a distinguished road
TIP120/121/122 have built-in protection diodes, look at the datasheet PDF and you will see them. That's why there is a schematic without diodes. I always tend to use external ones, that are usually faster than the build-in.
The higher the supply voltage, the inductance of the motor or the switching speed - the higher is the inductive spike generated, hence more heat in the diodes.
You seem to be driving the output transistors directly from the parallel port. The grounds are connected, so the current could flow from base so emitter and turn the transistor on.
Todor
running stepper motor with printer data pcb board helow General Electronics Discussion 3 06-17-2010 06:59 AM
Unipolar Stepper Motor Driver ( SLA7078MPR ) RCForge Open Source Controller Boards 19 04-07-2009 09:48 AM
Need Help!- Avr Unipolar Chopper Stepper Motor Drive Problems valasoft Controller Cards 0 07-13-2008 09:55 AM
Help on driver for this unipolar stepper motor percebon Stepper Motors and Drives 1 03-08-2007 06:41 PM
Looking for a unipolar 300+ ozin stepper motor pminmo Stepper Motors and Drives 1 07-12-2005 09:54 PM
