Old 06-25-2010, 07:45 PM
chevdrgtrk is on a distinguished road
2/4 pole motor hitachi VFD
Hello, I am trying to hook up a Hitachi SJ200 VFD to my 3 phase motor, but there is 2 different wiring diagrams for it, a 2 pole, and a 4 pole the 2 pole is rated at 3400 RPM, and the 4 pole is rated at 1700 RPM. Which would be a better connection?
Old 06-25-2010, 08:34 PM
Al_The_Man's Avatar
I would use the 4 pole connection, you can achieve 3400 running at 120hz.
Also the base speed of 1700 should give more torque at the lower rpm than the 2 pole setting.
Old 06-25-2010, 09:41 PM
mactec54 is on a distinguished road
chevdrgtrk
Is your 3ph motor 2pole or a 4 pole motor, the wiring in the drive should/is not any different from the 2pole to the 4 pole
The only difference is to set the right parameters in the drive for what motor you have
If you are talking about you motor, that can be wired 2 pole or 4 pole then it will depend on how fast you want the spindle to run as to which way you wire it up
Don't wire the drive wrong as many on the Zone have,as you will smoke your drive if you do
Mactec54
Old 06-27-2010, 09:51 AM
I opened up the motor and there is 2 sets of U, V, and W wires. Which set is 1, and which set is 2, and do I hook up one set, and leave the other set open? that's what I am getting from the motor plate
ID:	109935   Click image for larger version
ID:	109936   Click image for larger version
Old 06-27-2010, 11:36 AM
Al_The_Man's Avatar
Those connection look a little confusing?
Is there two distinct sets of three motor windings?
I am assuming that each three sets of terminals are connected inside the block across from left to right?
Old 06-27-2010, 08:25 PM
got it hooked up to the machine, next controlled by mach3
Need Help!- Totem pole output to drive a motor yervatn General Electronics Discussion 5 04-24-2010 07:33 AM
totem-pole driver packard1 Stepper Motors and Drives 1 04-22-2007 10:47 PM
9 wire motor and hitachi vfd Runner4404spd Phase Converters and VFD 5 04-06-2007 03:07 AM
shaded pole motor copper3416 General Electronics Discussion 4 12-04-2005 10:37 PM
Driving a 4 pole ac servo with a 6 pole drive TommyB Servo Motors and Drives 4 04-28-2005 01:17 PM
