Old 06-24-2010, 12:52 PM
woodchuck5 is on a distinguished road
How to get the most out of C10 breakout board?
I recently purchased a kit from Keling including a C10 breakout board and am buildng a 3 axis machine. I want to put limit switches at both +/- end of each axis and also have a home switch for each of the 3 axes.
The C10 ony has 5 inputs - pins 10, 11, 12, 13 and 15. Pin 10 is already used for the e-stop so that only leaves 4. Can I wire one of each of the X, Y, Z limits in series and connect that to say pin 10 then make pins 12, 13, and 15 be individual inputs for the opposite end limit switch and home switch?
I studied the video on Mach3 and it says these pins can be used for both a limit and home switch so from a software perspective it sounds like it should work.
Has anyone tried this wiring configuration?
Any help would be appreciated!
Thanks,
Brian
Old 06-24-2010, 06:56 PM
ee_t is on a distinguished road
http://www.cnczone.com/forums/showthread.php?t=106919
http://www.cnczone.com/forums/showthread.php?t=104789
Old 06-25-2010, 02:23 PM
Thanks! I had suspected that one input pin could be used for multipule limit switches. Appreciate the reply!
Brian
BREAKOUT BOARD BOBINETTE Stepper Motors and Drives 0 07-09-2009 10:24 PM
Looking for a Breakout Board SpeedsCustom General Electronics Discussion 14 01-04-2008 09:21 PM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Which breakout board to use erkiwi Stepper Motors and Drives 2 05-05-2007 02:08 AM
What is a breakout board? andy_ck87028 Stepper Motors and Drives 2 08-28-2005 05:37 PM
