Results 1 to 3 of 3
Thread: CNC Controller Advice Needed For homemade cnc mill
    Jun 2010
    Usa
    http://cgi.ebay.com/3-Axis-tb6560-CN...ht_4683wt_1137
    Could anyone tell me how good this would be as a controller for a 3 axis mill. I will be using 3 nema 23 steppers and will probably drive them at 24-36 at 2 to 3 amps. Is this a good price/quality ratio. I am great with electronics but 60 dollars seems like a good deal to save me the time of gathering all of the parts, soldering etc.
    THanks!
    Mar 2003
    Shelby Twp, MI....USA
    Do a google search here for tb6560.
    Lots of threads here.
    Jan 2005
    Toronto, Canada
    They should work if your power is 24v. If it approaches the max rating of the board, you will risk failure from transient voltage spikes. However, you will likely only get 1/2 the performance of a drive that can handle 50v.
  1. Advice needed to set up Taig CNC mill
    By Mark Scrivener in forum Taig Mills & Lathes
    Last Post: 10-19-2010, 11:26 PM
  2. EMCO Compact 5 Lathe/Mill - advice needed
    By n_maher in forum Mini Lathe
    Last Post: 04-15-2010, 09:26 PM
  3. Advice Needed For Selling A Mill
    By TZ250 in forum CNCzone Club House
    Last Post: 05-07-2008, 01:43 AM
  4. Series I mill - some advice needed
    By acerocket in forum Bridgeport and Hardinge Mills
    Last Post: 08-08-2007, 03:46 PM
  5. Advice needed for Mill Feed Rate
    By raytor in forum Benchtop Machines
    Last Post: 03-25-2005, 02:11 PM
