Old 05-23-2005, 02:33 PM
smarbaga is on a distinguished road
eni power supply
i recently aquired a new eni rf generator
eni model 25
2500 watts @ 13.56 KHz
what r these things used for and what can i do with it
the only thing i can find is plasma sputtering
what ever that is
thanks in advance
for your help and advice
Old 05-23-2005, 03:14 PM
Al_The_Man's Avatar
Its too bad that is around 2mhz otherwise you could build yourself a nice HF heating system, at 2500watts.
I believe it is used to produce hard carbon as is used in high tensile machine tool bits etc.
Old 05-23-2005, 03:23 PM
thanks Al...
13.56 KHz is not quite around 2 MHz .
the darn thing is watter cooled ( 2 gal per minuit)
i guess i'll fire it up ( from a distance ) and wait for the FCC
to show up, they'll tell me what it's doing ( lol.. it won't be the first time )
or i'll start pushing inexpensive hardened tool bits and teeth fillings..
Old 05-23-2005, 04:36 PM
Al_The_Man's Avatar
Sorry, I missed that on your 1st post, 13khz would be OK for HF heating of small parts, you would have to build a water cooled HF work coil.
Depends what kind of load impedance it works into right now.
It might be worth experimenting with unless you can find the right buyer, as it is probabally not a cheap item.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 10:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
