Old 06-13-2010, 08:42 PM
NCMColt is on a distinguished road
Cool what electronic circuitry is needed
I hope someone out there will set me straight as to what electronics is needed to run these motors. I managed to inherit two Oriental 100Volt AC torque motors with 15:1 gear heads. I want to build a wire coil winding machine to make solenoids and transformers. One motor will drive a reel or bobbin that the wire is coiled onto and the other drives a lead screw travelling back and forth on a rail or gantry laying the wire in neat rows.
Here is what I think is needed????
A power supply with AC output of 100V to power the motors, 5V DC to power a controller circuit and two drivers for each motor. I found out that these motors are from Japan and Oriental America does not sell the controller with the rated voltages. I hope Japan will reply to my request. But before I start buying I have to know for certain what electronics is needed.
Is it possible that simply synchronizing the speeds of the motors using something like a rheostat will be sufficient?
Old 06-14-2010, 08:22 PM
Zig Zig is offline
Zig is on a distinguished road
NO..
Rheostats wont do the job.
Cil winding is as precise as thread cutting and bobbins are unforgiving when stressed by a number of layers of wire .
There is a new package donated by a kind fellow which generates the G-code for a winding machine. Grab an old lathe and fit a top slide motor to it .
Fit a couple of shaft encoders and use EMC with this software ( its floating in these spaces as of a week or so ago) and You will be better off.
ALSO VERY IMPORTANT.... make a decent wire tensioning systems in line with the zen of wire. Otherwise You will stretch ( and change wire diameter or the layers will be applied in a sloppy fashion.
Good luck
Old 06-14-2010, 08:49 PM
Wink coil winding machine
Thank You zig for the advise. It makes more sense what you say I think there will be more precision using a lathe. In fact my brother in law has a bench top lathe I might just buy. I will begin my research anew.
CR Electronic blahic11 Europe Club House 2 11-19-2011 05:31 PM
RFQ needed - electronic boxes and supports dantm Employment Opportunity 7 03-09-2009 10:26 PM
Phase convertor needed for 3 HP CNC milling machine (rotary or electronic)? radioactive Phase Converters and VFD 11 01-25-2009 01:57 PM
New Machine Build- Electronic are just about complete! solodotcom DIY-CNC Router Table Machines 1 07-14-2008 08:58 AM
I need an electronic guru.... turmite General Electronics Discussion 9 01-12-2005 02:01 PM
