Old 06-11-2010, 01:34 PM
jandalaser is on a distinguished road
Wiring Saftey Stop and limit Switches
Try to Wire Limit switches and travel limit switches to a TB6560 Driver Board.
It has a Little White Plug on the driver board,With Inputs to P10,P11,P11,P13.
I would like to Have a E Stop,X & Y limit & X& Y Over travel Switches.
Any Body have a Wireing Diagram of Something like This?
Thanks for any Info!
Old 06-12-2010, 02:05 PM
UUU UUU is offline
UUU is on a distinguished road
eBay item 190396983708 is selling one of these boards and includes a diagram in the listing. Pin 5 of the connector seems to be the common ground, and pins one to four pass through to 10,11,12,13 of the parallel port.
Conventially you'd wire a switch that's normally closed between one of the pins and ground, so that the setting is "active high". Operating the switch breaks the connection and the voltage on the pin goes up to 5V. This is safer than a normally open switch, because if the wiring is broken then the software treats it as an emergency.
You can wire more than one switch in series so that operating either will break the connection.
Hope this helps.
Wilfrid
limit switches fitting and wiring deannos DIY-CNC Router Table Machines 17 02-13-2010 05:26 PM
Need Help!- How to wire E-Stop Buttons and Limit Switches which Pin in Printer Port guy2b1 General Electronics Discussion 7 06-09-2009 07:36 AM
DO I need LIMIT SWITCHES or E-stop?? max90272 Stepper Motors and Drives 5 07-14-2008 11:45 AM
Wiring IH limit switches Shepard Industrial Hobbies (Support forum) 10 03-20-2007 08:28 PM
Limit, Home and E Stop Switches Mr.Chips General Electronics Discussion 15 01-17-2007 09:02 AM
