Old 05-19-2005, 05:29 PM
radicooldude is on a distinguished road
Would this motor be more powerfull than my current one?
My current motor is the stock 1/5hp 1.8amp 110v one on the Harbor Freight Micro Mill. It is rated at 2000rpm.
The one i found is one from a jigg saw. It seems to have a variable speed control, and is rated at 3.7amps, 3500 rpm, and is brushed. I have no idea of what HP this translates to. Would this do better? Higher rpm and torque?
Thanks - zAck
Old 05-19-2005, 06:17 PM
sendkeys is on a distinguished road
motor sounds around maybe 1/2 hp maybe little less
sounds like it will work good,just make sure it had over heating protection . If you do long runs without being next to the machine
Old 05-19-2005, 07:21 PM
How would I know? There are just two wires going to the motor, + and -. Well, I will always be near, and check it often. I'll post a pic tommorrow morning.
Old 05-19-2005, 08:13 PM
Al_The_Man's Avatar
What other numbers do you have? voltage etc? If not, if you crank it up somehow up to 3500 open circuit and measure the voltage across the + - and multiply by 3.5 then divide by 746 which will equal HP.
AL.
Old 05-19-2005, 08:59 PM
oh only two wires... well then it's not the 120ac i was thinking it was hehe it might be allot smaller . Do what altheman said that will give you the true hp
Old 05-19-2005, 09:36 PM
I can't imagine it will get anymore than 18 volts, (i havn't measured yet.), it would be like .08 hp? I doubt that. The one on the mill now is just about the same size, and has less amperage. Will your calculations work for dc too?
Old 05-19-2005, 10:05 PM
Al_The_Man's Avatar
With two wires + & - I assumed it was DC.
If it is a universal motor then the previous procedure won't work.
Old 05-19-2005, 11:59 PM
Gold Member
Ken_Shea is on a distinguished road
Dang it Al_The_Man,
Is there nothing you do not know about motors ?
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Stepper motor: voltage vs. current ratings cnczane DIY-CNC Router Table Machines 3 09-08-2008 12:14 PM
Can someone please explain "chopper drive" stuart76 Stepper Motors and Drives 19 06-09-2007 07:31 PM
5vdc from paralell port, not enough??? thuffner3 General Electronics Discussion 8 11-23-2004 06:07 AM
Stepper question: torque re: current cnczane Stepper Motors and Drives 14 10-21-2004 08:30 PM
