Old 05-26-2010, 07:21 AM
epineh is on a distinguished road
Analog +-10v to 0-5v conversion
Hi, as the title suggests I would like to take a +-10v analog signal and convert it to a 0-5volt output to feed into a micro.
I would like to have the output linear so that with 0v input gives 2.5v out.
I imagine an op-amp would be the best option and I have been doing some research but have to admit I know very little about them. If anybody has a schematic to achieve this and is willing to share I would be very grateful.
Cheers.
Russell.
Old 05-26-2010, 08:25 AM
keebler303 is on a distinguished road
Op amps will indeed work.
You first want an amplifier with a gain of 1/4. The output of that amplifier will be +/- 2.5V. Then you will use and op amp adder to add 2.5V to the signal so you will get 0-5v out. Then you probably want to run that through another op amp as a buffer so you have some meaningful current available.
Matt
Edit:
Non-inverting amplifier: http://www.electronics-tutorials.ws/opamp/opamp_3.html
Summing amplifier (adder): http://www.electronics-tutorials.ws/opamp/opamp_4.html
More: http://www.eecs.tufts.edu/~dsculley/...s/opamps5.html
Old 05-27-2010, 03:20 AM
Hi Matt, thanks for the reply.
I think I am getting the hang of it...
So if I were to choose an op amp, would the LM348M - Quad 741 Op-Amp - SMD be suitable ?
From the datasheet it looks like the voltage range is OK, and I can use three of the op amps in the same package, is there anything I have missed ? The third stage you mention may not be necessary as the micro shouldn't draw a lot of current to do the ADC, but I guess since it is there I may as well use it.
While I am at it, would it be bad to use the fourth unused op amp in that package for the current sense side of things ? I am thinking this could also be fed into the micro to monitor current.
This is all for a servo power stage as you probably have guessed already.
Cheers.
Russell.
Old 05-27-2010, 08:18 AM
Ingenieur is on a distinguished road
Cheers.
Russell.
Hi, Russell,
as keebler303 described, you will need 2...3 OpAmps.
You can make it with only one:
Netlist:
R1 (50 kOhms) : OpAmpOut --- OpAmp(-)
R2 (50 kOhms) : OpAmp(+) --- GND
R3 (100 kOhms) : OpAmp(-) --- GND
R4 (200 kOhms) : Ref(+10V) --- OpAmp(+)
R5 (200 kOhms) : Signal(+-10V) --- OpAmp(+)
Every single OpAmp should do the job.
Supply Voltage : ( add min. 2V to Output-Range ) e.g. -2V/+7V or better -2V/ +10V so you can take +10V for Ref too.
Check if your ADC can handle (faulty) negative input voltage.
Cheers
Erhard
Old 05-27-2010, 11:29 AM
Russell
I think most any op amp will work for this circuit. If you are looking for high bandwidth, there may be better options. I think as long as the bandwidth of the op amp is above your A/D rate, you should be fine. You may want to incorporate some trimpots in your design so you can correct for errors caused by resistor tolerances.
Matt
Old 05-29-2010, 06:54 AM
Cheers guys, I will take that all that onboard, I do think that a better quality op amp is called for in this application, time for more research.
Russell.
Old 05-29-2010, 07:07 AM
Actually I just had a thought, all I am really after is something I can use to drive a H bridge, I could use an analog to PWM conversion and skip the micro altogether, basically what I am after is a class D amplifier, that may be a quicker way to go, I was going to use the deadtime built into the micro I was using but I could just use IR2184 or equivalent with built in deadtime.
Russell.
Old 05-31-2010, 09:58 PM
Russell
I'm not sure if chips exist to directly convert +/- 10 to PWM. I would think there would be but not sure. Digikey has over 400 "class d" amplifiers but I'm not sure if a chip for audio applications would be usable for this. It might be worth looking at a couple datasheets. The old school way to convert voltage to duty cycle is to compare the analog signal to a triangle wave.
The frequency of the triangle wave sets the frequency of the PWM. The higher the analog voltage, the longer the triangle wave voltage is under the analog voltage and the longer the duty cycle of the PWM. You can achieve all of this with a few more op amps.
http://www.play-hookey.com/analog/tr...generator.html
Matt
Old 05-31-2010, 10:02 PM
These should be helpful:
http://homepages.which.net/~paul.hil...enerators.html
http://www.simplecircuitdiagram.com/...-using-op-amp/
Matt
Old 05-31-2010, 10:21 PM
Pandinus is on a distinguished road
Just thought I'd mention OP-Amps in general are not "IDEAL" as in they wont go to the rails... If you want the output to go 0V to 5V the -V supply must be less than 0V and the +V supply more than 5V .. by as much as 2 volts for Some OP-AMPs...
but seeing as you want to convert +/- 10V you will most likely be using a +/- 12V supply for the circuit....
To convert a Hypertherm plasma torch output from -7 to 0 volts, to a +V up and down signal (Torch height control) I used an old PC power supply as it has a low current -12V and ample +12V for the rest of the circuits and relays in my control box...
Analog controll options zoeper Mach Software (ArtSoft software) 3 10-24-2009 09:36 AM
Need Help!- No Spindle 0-10v analog adam12000 Milltronics 0 07-12-2008 04:35 PM
analog +/-10V signal gen visky Want To Buy...Need help! 4 04-30-2008 09:40 PM
PWM to analog Drew Machines running Mach Software 7 10-09-2007 10:40 PM
Getting analog signal from pc roni21702 Computers and Networking 1 06-15-2006 01:34 PM
