Old 05-20-2010, 01:42 PM
Brenck is on a distinguished road
Cool Wiring Keling power supply to the electric plug...
Hi all,
I just got a 5020 keling power supply, on primary to connect them on the wall electric plug how I'm suppose to proceed?
On the website it says 2 red wires to neutral and 2 red wires to hot( I will run on 110v )
Does that means I will have to like solder both tips of the red wires together and both of the black and then each pair of wires go one on each side of the plug?
like this
==reds=====----- o
==blacks====----- o <--- little ''o'' s are the power plug
I'm asking because I messed up one transformer last month... = (
Thank you
Old 05-20-2010, 02:26 PM
Kelinginc is on a distinguished road
check here
http://www.kelinginc.net/KL-5020.pdf
AC power connections:
115Vac input: – 2 red wires to neutral & 2 black wires to hot.
220Vac input: – 1st red wire to neutral, 1st black wire to 2nd red wire, and the 2nd
black wire to hot.
www.kelinginc.net
Old 05-20-2010, 03:26 PM
It didn't help much...
I have checked before, in my post I mention this but I'm not quite sure if I get it right maybe its because the language and I dont understand the electric terms of hot and neutral, house plugs don't have positive or negative ( if its that what it means... )
Thank you
Old 05-21-2010, 11:26 PM
Fastest1 is on a distinguished road
Yes the 2 red wires are tied together if only 110 is used as the source. 220 is made from using 2 different 110 legs. That is why they had to seperate the red and 2 blacks when 220 is used.
Old 05-22-2010, 12:51 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
See pictures for more information.
ID:	107612   Click image for larger version
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-22-2010, 01:34 PM
Thank you for the replies, with the drawing stayed a lot easier.
Tags
keling power supply, primaries, wiring
Need Help!- Power supply plug HELP!!!! ChipKing Bridgeport and Hardinge Mills 3 04-22-2010 05:58 PM
Need Help!- Keling power supply judleroy General Electronics Discussion 4 04-18-2010 10:36 PM
Problem- Keling power supply yoyomin Automation Technology Products 5 01-22-2010 09:00 PM
Need Help!- Keling 5010 power supply wiring ronncat Automation Technology Products 1 12-13-2009 11:17 AM
Keling power supply? mcruff Automation Technology Products 5 09-23-2007 09:11 PM
