Old 05-19-2010, 07:09 AM
dex918 is on a distinguished road
Mach 3 PWM output to direct drive a MOSFET
Can someone confirm if the Mach3 PWM ouput from the parallel port can be used to drive the Mosfet to control the spindle speed?
My idea is like below.. Need to add a speed sensor for feedback to the Mach 3.
Name:	Spindle drive.JPG‎
http://9w2dtr.blogspot.com/
Old 05-20-2010, 09:55 AM
H.O H.O is offline
H.O is on a distinguished road
Look at the Vgs parameter for your MOSFET - most of them wants 10-15V on the gate to saturate but there are "logic level" ones available that seems satisfied with 5V. A flyback diode across the motor is probably a good idea and a proper MOSFET drive between the LPT-port and MOSFET too but then the partcount starts to go up...
Another thing to consider is that the frequency output from Mach3 is rather low as its original intent was to low-pass filter it and get an analog signal. It is possible to specify the frequency but the higher you go the lower resolution you get. If you're running at 45kHz and specify a frequency of 4500Hz you'd only get 10 discrete speeds - or duty cycles rather.
/Henrik.
Old 05-20-2010, 10:26 AM
Hi Henrik,
I appreciate the reply. Looking at it, looks like I have to abandon the idea unless I can:
1. Add a freq multiplier
2. Use a Logic level MOSFET (expensive!)
Regards.
Dexter
Clausing Lathe Conversion, direct drive or reduced drive Marty_Escarcega Stepper Motors and Drives 0 03-16-2010 10:43 AM
Need Help!- Direct Drive Plasma - Motor/drive/power supply? CPierce18 CNC Plasma and Waterjet Machines 1 02-05-2010 05:53 PM
Need Help!- Direct Drive Plasma - Motor/drive/power supply? CPierce18 Stepper Motors and Drives 0 01-29-2010 01:01 PM
UHU-Servo Mosfet drive problem Danii Open Source Controller Boards 2 03-07-2008 10:29 AM
MOSFET Gate Drive Circuit epineh General Electronics Discussion 21 10-24-2007 05:29 PM
