Old 05-17-2010, 03:43 AM
TarHeelTom is on a distinguished road
Wiring support doodads
I've seen them everywhere, but have no idea what they're called, and can't find them in any catalogs.
Usually a whitish or clear plastic thing which looks like the letter "P" from the side, but with two legs instead of one.
A hole through the leg for a screw, and a bigger hole in the top of the P where the wire goes through.
Very handy for making wire bundles stay somewhere that you want them to stay.
What are these doodads called, and what types of stores are most likely to have them?
Tom
Old 05-17-2010, 03:53 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Tom,
It is called a nylon cable clamp.
Home Depot, Radio Shack or any electrical supply house would stock them.
eBay also has several listings.
http://tinyurl.com/27bsqux
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-17-2010, 08:42 AM
Thanks, Jeff. Exactly what I was looking for.
Tom
Old 05-17-2010, 09:49 AM
Al_The_Man's Avatar
There is also adhesive tie wrap clamps that will work for many wire bundle sizes.
Old 05-17-2010, 10:28 AM
I've had way too many of those adhesive type clamps hanging loose in my office.
Suppose there are applications where they work, but....
Tom
Old 05-17-2010, 10:31 AM
Al_The_Man's Avatar
They seem to work best on smooth metal, I have had a devil of a job getting them off old panels that I have re-used.
Old 05-17-2010, 10:47 AM
I might try them again on my main power panel. It is a smooth metal panel box, and might be a suitable use.
Tom
Old 05-17-2010, 11:41 AM
TOTALLYRC is on a distinguished road
I find that cleaning the surface with brake cleaner or any solvent that leaves no residue makes them almost unremoveable.
Mike
Old 05-17-2010, 12:29 PM
I was thinking about using alcohol pads, which I always have boxes and boxes of.
tom
Old 05-17-2010, 01:07 PM
Al_The_Man's Avatar
I found that there is also a big difference between one double sided tape and another,
Someone gave me a sample roll of the 3M industrial quality, this stuff will remove paint after its been on for some time.
It seems the longer its on the harder the stick!!
  #11   Ban this user!
Old 05-17-2010, 01:11 PM
tom
I would do a test to be sure but as long as they are just alcohol and nothing else they should work fine.
3M always seems to make the best stuff.
Mike
Need Help!- support rooboy Carken Products (Deskam, DeskCNC etc) 1 12-17-2009 06:54 AM
Need Help!- support rooboy General CNC (Mill and Lathe) Control Software (NC) 0 12-17-2009 05:59 AM
Support. Jens H Automation Technology Products 21 09-30-2009 08:51 AM
Problem- no support ljd10 Carken Products (Deskam, DeskCNC etc) 3 09-30-2009 02:27 AM
Need Help!- PC CAM support tengo8 Bridgeport and Hardinge Mills 1 03-03-2008 06:25 PM
