Old 05-13-2010, 09:11 PM
CATCH22 is on a distinguished road
Question Wiring Bridgeport motor question?
I am starting to wire up my bridgeport motor,but its a jin shin motor that is 220volt it is also 2 and 4 pole my question is there are 6 wires, 3 are all black and have U1 V1 W1,then there are 3 more wires that are all red with U2 V2 W2, should I be hooking up either all the blacks or all the reds I think that is how it should be done but I dont want to fry the motor.I will be using a VFD to run the motor single phase in and 3 phase out. Should I be hooking up T1 to U1,T2 to V1, and T3 to W1 because Im not really sure and cant find any info. on the internet anywhere.
Thanks Mike
Old 05-13-2010, 10:22 PM
Al_The_Man's Avatar
You may have two sets of windings, one for each speed configuration, test the continuity between all the reds and all the blacks, if there is no connection between each bank of three, then usually one bank is used, the other left unconnected.
Need help wiring up servo Bridgeport Interact II Shanghyd Bridgeport and Hardinge Mills 8 03-26-2010 11:21 PM
Need Help!- Bridgeport R2E3 Wiring pvbpoet Bridgeport and Hardinge Mills 1 06-26-2008 02:09 PM
Bridgeport S1 2V3E Wiring wcarrothers1 Bridgeport and Hardinge Mills 0 05-21-2007 08:58 AM
Bridgeport Retrofit Wiring Diagram UKRobotics General Electronics Discussion 0 09-18-2006 04:39 AM
Bridgeport Starter Assembly Wiring kramstr Bridgeport and Hardinge Mills 2 08-28-2006 12:39 PM
