I have this bridge saw with no controller. I have spare servo drives, motors and some stepper motors and drives. Also I have AC Drives with gearbox motor. The AC Drive is Teco MA7200 with lot of features. which I can use to drive the cutter head if possible. I think the gearbox was previous used with the saw. I don't plan to use a computer to control this saw because is just one axis only forward and reverse direct. What I like to have is the following: 1. Control the speed of the axis Forware and Reverse during cutting. 2. Jog to position with different speed. 3. Automatic home position when it hit the right limit switch. What is the best solution for this requirement. |
| I'd make some sort of standalone controller using a microcontroller. All you'd need is dir and step signals really, and then some inputs such as a joystick. As for the limits, it'd be as easy as wiring it to an input and writing the proper code. |
Do you have any experience programming microcontrollers? |
| Heck you're only going forwards and back and need to control the speed and a jog? If your servo drives use analog signals for speed control, just a simple rheostat will work. Anything more is extra work. The servo drive ends up working like a simple DC drive |
| Many drives also have fwd & rev limit inputs, each only allow movement in the opposite direction. Al.
| Many commercial servo drives have such features built in . Check out the Emerson FX series or the contemporary equal for ideas. Perhaps a little spendy, but good solid drives combined with Programmable logic control capabilities. |
| Thanks |
| If you list the drives and motors that you have and looking to using, it may be possible to offer more assistance, you don't necessarily need intelligent drives for that application. Al.
#10
| It's not required, but I think it'd be nice to be able to run them at a known speed, and adjust it to fairly precise speeds on command. It's not necessary, but for the amount of work it'd take it might be worthwhile. |
#11
| Al.
#12
| Currently I have two AC Drives that I use for this project the Drives are from TECO model MA7200 and 7300CV. The 7300CV has PLC functions built. This is description for the drive. I think it should be able to do what I need but I am able to hookup the motor manual push the button for forward and reverse. What I like to do is able to automatic home when it the reach the end limit switch and before home it actuate a switch and when it sense successfull activated and activate the reverse to home position. 7300CV Series Compact Vector AC Drives Product Features Auto-tuning Sensorless Vector Control with V/HZ mode Pulse Width Modulation (PWM) utilizing IGBT Technology Built-in PID Control 2 Analog Inputs: 1 master speed reference accepts 0-10VDC, 4-20mA, and 0-20mA signals and 1 multi-function (0-10VDC) Digital Inputs: 5 PNP/NPN selectable 1 Analog Output (0-10VDC) 2 Multi-function Digital Relay Outputs Built-in dynamic braking transistor Electronic overload protection and stall prevention Ground fault and short circuit protection Built-in PLC functions at no extra cost Ladder logic programming, up to 40 rungs of code Up to 7 Digital Inputs, 2 Relay Outputs, 2 Analog Inputs 8 Comparators (4 analog, 4 encoder) 8 Timers, 4 Counters, 15 Internal Relays |
| Single axis motion without PC? | marzetti | General Electronics Discussion | 7 | 01-02-2010 10:25 AM |
| Newbie- Gecko 3 axis solution | haku | Gecko Drives | 0 | 03-11-2008 10:26 AM |
| Simple Z axis solution for BP J Head retro | DennisCNC | Bridgeport and Hardinge Mills | 0 | 07-23-2006 10:41 PM |
| 4th axis solution to solve gantry skewing, geckos and servo, and axxus questions | CuttersCov | General CNC (Mill and Lathe) Control Software (NC) | 1 | 02-20-2006 04:10 PM |
| single axis controller | robm7 | Stepper Motors and Drives | 4 | 10-22-2005 01:30 PM |
