I am looking for suggestions for the best optical switch i should use. It needs to be fast and reliable. It will be seeing up to 1000 pulses per second and connected to the parallel port. It is mounted next to a metal slotted wheel. The ones i am using now start to miss pulses at about 300 pps. Thanks . Lyle |
| Take a look here. Key part is Schmitt trigger 7414 in SOT case: http://www.chipmaker.ru/index.php?showtopic=33916 |
| I am at work right now and can't remember. It can easily source enough power to put the pin high. It seems to miss pulses at high speeds and I am unsure why. It is set up as pictured. I have tried a few opto interrupters removed from a newer printer. I have some old dot printers if they would work better. |
| OPB917 Try re orienting the output transistor as and open collector output. Connect the emitter of the phototransistor to gnd (v-) and use the collector as your output. The collector will be low when not interupted and can be pulled high via pullup resistor when interupted by your flag. Steve |
| Optical switch, on when I expected off | will gilmore | General Electronics Discussion | 9 | 04-23-2010 01:49 PM |
| Optical interupt switch implementation. | owhite | General Electronics Discussion | 26 | 07-26-2009 04:27 PM |
| Optical Switch w/Interrupt mechanism | cnczane | DIY-CNC Router Table Machines | 1 | 11-10-2004 08:51 AM |
| WHATS THIS?? - Optical Switch?? | High Seas | General Electronics Discussion | 5 | 07-13-2004 07:54 PM |
| optical switch | natchez | Xylotex | 3 | 05-01-2004 07:45 AM |
