Old 05-11-2005, 01:28 PM
trilect is on a distinguished road
I'm looking for a simple speed controller for a brushless AC motor.
Hi folks, I'm putting together a simple shop air cleaner and need a speed controller for the beast. The motor I need to control is a 1/5 hp induction motor attached to a cage fan.
I found loads of brush motor control schematics on the web but none of the VFD type.
Any advice?
Old 05-11-2005, 01:42 PM
Al_The_Man's Avatar
I don't think you will find many for 1ph induction motor as they do not control well, they drop out of speed control and stall when dropped too low or loaded.
For 3ph there is quite a few designs.
Al
Old 05-11-2005, 02:11 PM
This induction motor appears to have 4 field coils, I wonder if I could possibly cut the wires going to them and setting up a switch system to cut them in and out of the circuit.
Do you think that would work?
Old 05-11-2005, 03:35 PM
Al_The_Man's Avatar
I would'nt even attempt it, you will probabally screw the motor right up. If you really want some control, a used three phase motor that size should not be much, although the lowest voltage is probabally going to be 220v, the input to the VFD would be 1ph.
If 220 is a problem you could look at a small universal motor as is used in shop vac's etc. There are many controllers for this type.
Old 05-11-2005, 08:45 PM
DieGuy's Avatar
DieGuy is on a distinguished road
You know the new furnace motors have 2 speed blowers in them.
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 09:58 PM
Speed range for VFD and three phase motor RotarySMP General Electronics Discussion 7 04-20-2005 02:05 PM
Does controller change axis motor speed? samualt DIY-CNC Router Table Machines 5 10-10-2003 04:05 PM
