I have a brushed DC motor rated at 160VDC 12 Amps (2.3hp). I want to control it with a Granite Devices controller, or similar. What is the best way to provide the 160V DC to the controller from 240V AC single phase? (and cheaply) I assume this could be done with a transformer, bridge rectifier and capacitors, but I have never seen a transformer of this size at my local electronics shop (500VA max). I already have a couple of amplifiers for AC servos which take the 240v AC and have a 340VDC bus. I assume they just rectify the 240vac into 340vdc. Are their off the shelve products to do this? Thanks, Frank |
| Not sure what is available in Australia, but do you have 'construction Site' transformers that are 240-120 as they do in the UK? The 120vac will give you the DC you are looking for if the VA is there. Alternatively try the local Electrical Suppliers for a similar 240/120 version. Just a couple of options to look at. Al.
| Thanks for the tips. On ebay (Australia) there are lots of 240 to 120 step down transformers, they say to run items from the US. Up to 2000VA, for $A195. (Like this one, item #180496483937, http://cgi.ebay.com.au/240V-TO-110V-...item2a066dc661) I assume these are just a transformer in a box. Are these suitable, if I gut out the transformer? Anything to watch out for in terms of quality? |
| The seller seems legit, 100% F.B. rating. There is not alot to a transformer to check, as long as it is copper winding and the Kva rated properly it should be OK. You could send a question to through ebay to one of the recent buyers to get an opinion. Al.
| fitting a 110v or 220v single phase spindle motor on a 3 phase machine | mwood3 | Benchtop Machines | 12 | 10-12-2009 09:53 PM |
| Need Help!- Wiring Slo-Syn 240V 1 Phase Motors | PerPlexed | Servo Motors and Drives | 7 | 06-16-2009 10:24 PM |
| Can I convert single phase motor to three phase? | Jim Estes | Phase Converters and VFD | 30 | 01-24-2009 02:41 AM |
| 240v supply and 208v motor | isu19151@verizo | Bridgeport and Hardinge Mills | 8 | 11-29-2007 01:23 AM |
| 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... | kochevnik | Stepper Motors and Drives | 6 | 10-22-2006 10:48 PM |
