i've put together a 60V unregulated power supply and would like to add a small voltage regulator circuit to provide 24Vdc to two small cooling fans (0.070A each). i wired it in, but my last 317T (R.I.P.), didnt like 60V input. it worked for a little while ![]() tech sheet says 40V max input. best way of getting 35V-40V from my power supply to my regulator circuit without affecting the 60V output? (don't mind if it drops a volt or two) -anthony |
| You could use a power pass transistor like the applications sheets show, but if you are going to add too much you may as well get the HV version, also the T03 package offers a bit better ability to Heatsink better. Al.
| Extremely basic machining question. | touser | General Metalwork Discussion | 9 | 06-19-2005 12:51 AM |
| Question about power supplies | dowling177 | General Electronics Discussion | 1 | 01-28-2005 07:01 AM |
| Hobbycnc controler question | chas | Hobbycnc (Products) | 3 | 09-09-2004 05:00 PM |
| Just a question about plunge milling. | Machine1 | Hard and High Speed Machining | 4 | 01-28-2004 08:36 PM |
| HF lathe question | rs1300 | General Metal Working Machines | 0 | 01-19-2004 11:22 AM |
