I have a servo with a sanyo denki encoder, 15 years old. I had this working at one time and I remember it needed a couple 1000 ohm resistors in the scheme. Unfortunately I no longer remember the wiring. Can someone help. Thanx, Ozzie |
| Can you identify any of the wires? The resistors were probabally pull up from A & B to 5+vdc. If it was a couple, then most likely a single ended encoder, 4 wires or 5 max if marker also? Al.
| I am just guessing, but if there are only A & B output, (not differential) then the odds are it is open collector and this was the reason for the pull-ups. If so then 1k on each A & B to 5vdc. This was often a common arrangement on the smaller S.D. motors. Al.
| C could be the the marker pulse, as in A B & C? You can always try them without the pull-up if the transition voltage does not go from 0 to 5v on the A & B, then use a pull-up resistor. Al.
| Problem- Sanyo denki P5 | virgoviggo | Servo Motors and Drives | 5 | 01-22-2011 10:37 PM |
| Sanyo Denki Drive | RAC | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-21-2009 11:09 AM |
| Need Help!- Sanyo Denki 65BA030VXT01 | virgoviggo | Servo Motors and Drives | 1 | 05-09-2008 03:22 PM |
| G20 and Sanyo Denki Super-U | happytriger2000 | Gecko Drives | 1 | 05-20-2007 07:24 AM |
| Sanyo Denki Help | Gary D | Stepper Motors and Drives | 0 | 04-06-2007 08:17 AM |
