Hi, Because of excessive flex between the two X axis gantry sides I'v decided that installing a motor on the other side is the only way to overcome the problem. The trouble is that the second motor needs to rotate the opposite way to the first. If I'm using the same output channel from the driver for both motors is it just a case of swapping the wires on one to reverse the polarity? The motors are Astrosyn MY103H702 and the driver is a TB6560 3 Axis powered by a 24V 10 amp power supply. Any suggestions would be gratefully received. Rob. |
You could always change (A with A') OR (B with B') phases on the motor, to make-it rotate on the opposite way |
Btw, I'd sooner reverse the wiring. I was just throwing the software option out there. |
If "I'm using the same output channel from the driver for both motors" (as stated on the first post), then reversing wires is the only option. |
Sorry |
| Grinding and unexpected axis movement if rapiding 2 axis | DarkSabre | Taig Mills & Lathes | 4 | 03-25-2010 11:37 PM |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
