I have a keling 54v 13amp unregulated power supply with. It is a toroid transformer and a small rectifier board. When I first fired it up and tested it about a year ago it read +53.4, -53.4v and the common was about 28v. Now the supply reads +55.4v and -55.4v or close to that. What causes the voltage to change like that? The reason I ask is my board is 55v and I need to keep the voltage below that. Is there a way to lower the output voltage by just a couple of volts. I'm also wondering if I can add a fuse somewhere to protect against over voltage and over current? Any help or advice would be appreciated. Thanks Judleroy |
| If your mains supply happens to fluctuate, the output will also, which can happen at peak demand times of the day. If you want to keep it down to below a certain level, the easiest way is to take a few turns off the toroid secondary, they are usually wound on last, ~2turns/volt. Al.
| Just make sure you have the right secondary winding if there is more than one. I have often wound on a separate auxiliary winding on top for 5,12 or 24v, whatever I needed at the time. Al.
| There are 4 output windings off of the toroid. The toroid says they are blue-green-blue-green. The two blues together give me +54v and the two green give me -54v. The toroid says O/P: 1. Blue-Green and 2. Blue-Green. Would I take 4 windings from both #2 windings (blue and green) to remove 2 volts from the supply? Thanks Again Judleroy |
| Problem- Keling power supply | yoyomin | Automation Technology Products | 5 | 01-22-2010 09:00 PM |
| Need Help!- Keling 5010 power supply wiring | ronncat | Automation Technology Products | 1 | 12-13-2009 11:17 AM |
| Keling Power supply | judleroy | General Electronics Discussion | 11 | 08-25-2009 12:08 AM |
| Keling motors, drivers and power supply connections | Nitroghost | Automation Technology Products | 14 | 03-13-2008 11:18 AM |
| Keling power supply? | mcruff | Automation Technology Products | 5 | 09-23-2007 09:11 PM |
