Old 03-30-2010, 10:46 PM
evander is on a distinguished road
Need help in opto isolator circuit!
Hi guys, i have a problem with this circuit. I do not know what happened to the opto isolator but when i turn on the switch the "?" will get turned on but when i off the switch the "?" will still be ON. any idea what happened? i suspect is the problem with the 3.9k resistors. Advice pls..thanks!
Old 03-31-2010, 09:25 AM
Al_The_Man's Avatar
If you do not have a limiting resistor in the diode circuit you will blow the diode, but I would not have thought that would have affected the output?
It is only ~6mA, what is it feeding into?
Old 03-31-2010, 09:35 PM
Sorry for some misunderstanding. Here is a better picture of it. The problem is i do not know what is inside the "?" and what could possibly be the circuit that will cause voltage still floating around that area?
Old 03-31-2010, 10:05 PM
Al_The_Man's Avatar
Disconnect it from whatever is in the "?" and switch on and off while measuring the voltage across the 3.9k resistor, if it switches from 0 to ~20v, then you know the opto is working and it is the load that is affecting the outcome.
Old 03-31-2010, 10:10 PM
Which load is affecting if the opto is working?
Old 03-31-2010, 10:15 PM
Al_The_Man's Avatar
You need to know the characteristics of what you are inputing to in order to come to the right conclusion.
Old 03-31-2010, 10:19 PM
Is there any possibilities of that 3.9k resistor?
Old 03-31-2010, 10:24 PM
Because i do not know what is in the black box so i thought i can figure out from here what is in it that make it looks like latching.
Old 04-01-2010, 01:54 AM
Does it matter with any ground loops?
Old 04-04-2010, 09:20 AM
Al_The_Man's Avatar
What is the piece of equipment exactly, you are interfacing to?
  #11   Ban this user!
Old 04-04-2010, 11:11 AM
What equipment? this circuit is what i know...but they wont reveal what is in that "?" box.
Old 04-04-2010, 12:42 PM
Al_The_Man's Avatar
But what IS the box??
Opto-Isolator problem G201 ? Clyde Gecko Drives 4 08-20-2008 06:09 AM
Opto-isolator problem? Me2 Gecko Drives 2 10-27-2007 08:31 AM
feedback isolator for laser owhite Laser Engraving & Cutting Machines 9 04-14-2007 09:34 AM
LPT Opto isolator Circuit Schematic graphpix General Electronics Discussion 1 02-20-2005 04:13 PM
How to sense a switch with both opto-isolator and logic? arvidb General Electronics Discussion 8 09-01-2004 10:04 AM
