Hi, I have never done anything like this but I am an engineer....not sure if thats going to help.....HELP.. I have purchased from EBAY; three Bi-Polar steppermotors (8 lead) ,3 controllers ,a power supply ,and a break out board from Wantai Motors. But I dont know how to wire them together. here is a link to something similar http://cgi.ebay.com/3Axis-Nema-34-St...item2a05d6fb15 Stepper motors.... 8 wire... I used a volt meter and have found the 4 wire pairs so i thinki good there. 1) How should i wire them? In parallel or series? then torque rating is the same. Controllers..... the controllers are "SD-2H086MB" with 12 connections A+ A- B+ B- These goto the stepper motor wires? DC- DC+ These goto the power unit +24v -24v PULS+(+5v) PULS-(PUL)..........P2 on Breakout board DIR+(+5v) DIR-(DIR).............P3 on breakout board ENBL+(+5v) ENBL-(ENB)..........I think this is left un-connected I dont know how to connect the three i have not commented on Can anybody help please Madaxe |
http://www.wantmotor.com/ProductsVie...&pid=75&sid=80 With stepper motors just ringing them out isn't quite enough, you have to phase them correctly too in order for them to run. Most prefer bipolar parallel wiring. Now as for your mystery connections PULS sounds a lot like "PULSE" to me so that would most likely be your step input. DIR is obviously DIRection abbreviated, and I'm going to go out on a limb here and hazard a guess that ENBL is ENaBLe. Hint, lots of electronics do not function unenabled. Slow down a bit, take a deep breath, and just work through things a step at a time. |
| The reality is you still need to phase a stepper motor correctly in order for it to run right. I never had to resort to it yet but the "Bill Krause says:" method sounds like it should work. http://www.piclist.com/techref/io/stepper/wires.htm Have fun! |
| Is this kind of Stepper Motor very slow? Stepper Motor 1, Technical Specifications Part No.: 85BYGH450C-012 Frame Size: NEMA34 Step Angle: 1.8 degree Voltage: 5.7V Current: 3.0A/phase Resistance: 1.9 Ohm/phase Inductance: 22 mH/phase Holding torque: 9.3N.m 1317oz-in Rotor inertia: 3600g-cm2 Number of wire leads: 4 Weight: 5 kg Length: 151mm |
| 3 NEW KL-6050 MICROSTEP DRIVERS WITH C10 BREAKOUT BOARD ALSO 5VOLT POWER SUPPLY $100 | heilcnc | EBAY ADS | 2 | 01-08-2010 06:12 AM |
| 3 NEW KL-6050 MICROSTEP DRIVERS WITH C10 BREAKOUT BOARD ALSO 5VOLT POWER SUPPLY $150. | heilcnc | EBAY ADS | 4 | 01-04-2010 06:56 PM |
| 3 NEW KELING-4030 MICROSTEP DRIVERS AND BREAKOUT BOARD,+5V POWER SUPPLY | heilcnc | EBAY ADS | 5 | 09-27-2009 08:01 PM |
| power supply size? for multi wire (total 250 inches of wire) | DanOSB | CNC Wire Foam Cutter Machines | 5 | 03-02-2009 04:34 PM |
| Need a breakout board that can supply 25ma | damae | General Electronics Discussion | 14 | 07-13-2005 11:48 AM |
