Results 1 to 8 of 8
Thread: 48V Power Supply Source ??
    Jun 2003
    florida
    Question 48V Power Supply Source ??
    I am looking for a 48 V power supply. Need 15 Amps......
    Any suggestions ??
    I'll even build one if someone knows which direction to point me .... any help is greatly appreciated.
    Tom M
    Moderator HuFlungDung's Avatar
    Mar 2003
    Hi Tom,
    Power One is a pretty standard source for this type of stuff. Here's a page to get you going:
    http://www.power-one.com/products/acdcintro.html
    Registered HomeCNC's Avatar
    Mar 2003
    You can make your own. I like the Toroidal transformers by Plitron
    http://www.plitron.com They are like getting two transformers in one.
    You can get the standard Plitron #097018201 Output is 35 VAC at 8.93 Amps. Connect the output in parallel to double the amps to get 17.86 Amps $66.02 plus shipping Should give you 49VDC at almost 18 Amps.
    Get the Cap from http://www.mouser.com you will need at least a 30,000 uF cap so get the 75 Volt 37,000 uF cap
    #539-CGS75V37000 $38.14
    Last is the Bridge Rectifier. Mouser has them too.
    #583-MP252 200 Volt 25 Amp rated for $2.77
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Registered Lanny's Avatar
    Apr 2003
    Arkansas
    Imagination is the beginning of creation. You imagine what you desire, you will what you imagine and at last you create what you will
    Jun 2003
    Quebec
    48 volts
    Hi Tom,
    One of the things you want a look for a cheap 48 volts sources are old (or very old) telephone system at a local phone compagny.
    Almost all the old phone equipment use -48v for driving the regulars housephones. Most of these equipment are very robuste and i had seen some of these DC charger up to 100 amps.
    Good luck
    Pierre
    Phee
    Jun 2003
    Quebec
    48 volts
    Hi Tom,
    Good luck
    Pierre
    Phee
    Gold Member
    Mar 2003
    Registered CAMmando's Avatar
    May 2003
    Phila PA, USA
    I just got this one for $10 + Shipping. 48V 30 Amps @ 115 V AC Input.
    Attached Thumbnails Attached Thumbnails 48V Power Supply Source ??-cherokeepowersupplyi2.jpg
    Wee aim to please ... You aim to ... PLEASE.
    1. How does a power supply work.
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 07-27-2011, 10:40 AM
    2. Diy Power Supply Choices
      By berin in forum DIY CNC Router Table Machines
      Last Post: 07-13-2005, 04:47 PM
    3. 5 Volt Power Supply Tripping
      By murphy625 in forum General Electronics Discussion
      Last Post: 02-27-2005, 10:05 PM
    4. Choosing a Power Supply for Retrofit?
      By pfeist in forum General Metal Working Machines
      Last Post: 05-23-2004, 11:36 PM
    5. Traco TSL480 48V Industrial DC Power Supply 10A
      By ullbergm in forum General Electronics Discussion
      Last Post: 03-06-2004, 08:13 AM
