Old 03-27-2010, 02:47 PM
Fastest1 is on a distinguished road
1 or 3 phase?
I am thinking of removing my dc servo motor and replacing it with an AC motor. I would like to run a 1 hp 120vac tefc style motor if possible. My questions are
Is there a problem with 120v for this small hp motor?
Can I control the speed thru Mach of a single phase 120v motor and how? PWM? VFD?
I see alot of suggestions of a 220v 3 phase motor and a vfd/inverter or something. But if 1-1.5 hp is all you need is that necessary? I believe that I could run an optical sensor on a pulley for a tach in my G540 then threading would be fine. I dont have 220 in my garage yet and nothing else on the machine needs 220 now, even though the DC servo motor is a 148vdc motor. It uses a step up transformer. I dont mind using the existing motor but it means reconfiguring the old power supply and controller and interface it with the G540. Might be much easier to go AC.
Old 03-27-2010, 03:22 PM
Al_The_Man's Avatar
Both methods generally use ±10vdc to control speed, so it will need a PWM to analogue converter for either.
For a 120vac motor it is going to be 1 phase and they do not take kindly to variable speed, so if going AC you would need a 3 phase motor, which would mean a VFD with 240v 1phase input.
Old 03-27-2010, 04:58 PM
kevin swan is on a distinguished road
look up KB electronic controles model KBVF-24D it is 120 volt in put 3 phase output i have one on my hone they probley make nicer vfds now as this one is apx 8 yrs old
Old 03-27-2010, 08:56 PM
Kevin are you running a 220 3ph motor on 120v with that controller? Do you get the marked rpm of the motor? BTW they still make the 24D & F. Also a 26D & F. Are you controlling the rpm thru Mach also?
Old 03-28-2010, 06:12 AM
Fastest1 I am running a 1/2 hp 220v 3ph moter with this. it has no tach so I cant veryfy the rpm. I think I run it at apx 800 rpm max.The control came built in the hone as oem .The speed is controled with a pot. as the hone is non cnc good Luck hope some of this helps. kevin
Old 03-28-2010, 08:09 AM
mactec54 is on a distinguished road
Fastest1
You need to do more searching, try the drive ware house, for a Hitach drive you will get one to do your job from them, they have 120v input 220v 3ph out & you can run most drives with Mach This is one of many drives that will do the job
You need to have a 3phase 220v motor as well not single phase
Mactec54
Old 03-28-2010, 09:49 AM
Thanks to all regarding the responses and opinions. I will check into the drives. I am still curious why a single phase is any different than 3 phase regarding speed control. On the typical drives we are referring to (that use 120vac in and produce 220vac 3 ph out). If I use a model for the 1.5-2hp, is it alright to use a 1 hp with it and just have the extra capacity if I want a larger motor in the future? I am also trying to retain the motors original location and size may be an issue. A 56C might fit but it is going to be close. I am going to look into other frame sizes.
Old 03-28-2010, 10:39 AM
Al_The_Man's Avatar
A single phase induction motor is actually a split phase motor that most use a capacitor to split the phase, dropping the frequency tends to make it drop out of run when going to low rpm's.
You can oversize the VFD, the motor details you are using is loaded into the parameters to take care of this.
The 1 phase motors you may see with speed control are usually Universal motors, which are quite a different motor.
Old 03-29-2010, 07:48 AM
Al thanks for the constant source of answers! Most of it is over my head but you help the layman so well. Good to know that oversizing isnt an issue. Now time to look at motors though I am still considering resurrecting the DC Servo motor and its controls.
Old 03-29-2010, 09:17 AM
Al_The_Man's Avatar
What is the issue with the present DC servo/spindle?
  #11   Ban this user!
Old 03-29-2010, 10:18 AM
Al, the old machine is a Dyna DM 3000. The controller was missing from day 1 (the machine is used) and all connectors had been removed from their places on the boards. After a good cleaning and no parts to install, I started plugging in all the connectors. The wires were all marked very well as were the boards. Everything went right into place. Hit the power button and it all came to life. Of course I had no way to control it and I wasnt going back to Dyna's 1980's electronics. But the spindle did work and I had rpm control thru the pot. I pulled all of the existing electronics out including the spindle driver board. The machine has a transformer in the back that steps up the 110vac to 148vac and then rectifies it to DC and has a relay that I am guessing turned the spindle on and off. I would need to resurrect the power supply (which I would like to do if only for the knowledge) and retain the DC motor til it proves to be too weak. It might not prove too weak for me. On the driver board besides the typical inputs and outputs for the motor control, there seems to be a few other plugs that connect to the board. I dont know if they are all needed or not. Also there is some form of amplifier on the circuit. The manufacturer is still in business for their bigger machines but these educational models were discontinued quite a few years ago. They are helpful to an extent but arent really into the technical end of the older controls. I could attach a picture or 2 if that would help. The motor itself is a SEM MT30. I guess the thing that intimidates me the most on the DC motors is all of the wires going into the housing, they are well labeled but dont make sense to me. The wires seem to be marked just like each axis. Anyway I would love to use what I have til I need or learn more. Give me hope Al!
Old 03-29-2010, 10:43 AM
Al_The_Man's Avatar
I put a SEM servo motor on a lathe for a friend, I used a KB 4 quadrant SCR drive off ebay, and ran it off the 240vac.
Using the tach option together with the servo tach gives good rpm control and the 4 quadrant gives braking and bi-directional control with one pot, or ±10vdc from a controller if you need it.
The 2 quadrant, you have to use a reversing contactor and uni-directional pot control.
Convert three phase transformer to single phase? jimjovan General Electronics Discussion 3 12-10-2009 02:17 PM
fitting a 110v or 220v single phase spindle motor on a 3 phase machine mwood3 Benchtop Machines 12 10-12-2009 09:53 PM
Newbie- 2 phase driver & 4 phase 6 wire stepper HELP! mark in aus Stepper Motors and Drives 2 06-02-2009 12:31 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
wtb: 20 or 30 hp phase perfect phase converter gaugemate Want To Buy...Need help! 0 10-23-2008 12:06 PM
