Please see this item...http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true Why does it state the inputs as such "ONLY"? Can't any amount of input voltage be applied and the resulting output be relative to the input? And how is the amperage affected by lowering the input to 115 or 120 VAC? |
Chris |
| Generally you can get away with it, but the KVA rating and the voltage drops proportionatley to the difference in voltage you apply. The efficiency drops slightly also, although you may not notice it unless you run at max. current. A transformer is designed to provide a certain magnetic field to overcome the iron losses etc and this depends on the turns/volt ratio and the voltage applied. You effectively doubling the turns/volt ratio by halving the voltage. Al.
| Thanks All! I ask because I am inputting 115VAC into a toroid designed for 230Vac (Remember Al? the one I took way too much secondary off to bring down the ouput voltage....I was exasperated after drilling,chiseling, picking out the big epoxy core and didn't check often at intervals for output voltage). Was wondering if these types of transformers reacted about the same. ...Always looking for more options for supplys(at a good buy)...having fun experimenting with electricity... |
In my early days in the Electronic/electrical field, toriods were rare as the technology for winding them efficiently had not been developed, as this was during my relative poverty era. I had to resort to dismantling Square type transfomers for customize rewinding, if you really want a challenge try these types some time. Al.
| Compumotor microsteppers | Stevie | General Electronics Discussion | 46 | 11-15-2007 08:35 AM |
| Dirction / Step lines! | bigal | TurboCNC | 2 | 02-06-2005 01:51 PM |
| Need input for servo control systems | CNCadmin | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-31-2005 10:45 AM |
| Active High/Active Low | Sanghera | General Electronics Discussion | 21 | 11-06-2004 08:47 PM |
| Tool offset input | Mircea | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 05-28-2004 06:16 PM |
