Old 04-28-2005, 11:53 AM
Don C is on a distinguished road
Photo limits
Want does it take to have a photo limit switch instead of regular limits. want would the circuit look like.
Don C.
Old 04-28-2005, 12:03 PM
Al_The_Man's Avatar
Go here and look up the slotted opto coupler description.
http://electronents.v21hosting.co.uk...plications.htm
Al
Old 04-28-2005, 12:17 PM
Gold Member
bgolash is on a distinguished road
Here`s a part number from http://www.digikey.com/ 425-1060-5-ND
I`m going to use these. They work with the bob campbell`s breakout
board. If your using that board here`s instructions for the wiring.
Wire a 1k resistor in series with the anode pin 3 and the +12v terminal and 2 to the gnd terminal and 1 to signal
terminal.
Old 04-28-2005, 12:24 PM
photo limit
could you draw that circuit out for me? You have me lost.
Don C.
Old 04-30-2005, 02:54 PM
Gold Member
Here`s a pic of the wiring
Hi
I am no expert with this wiring. I just tried the photointerruptor
with my breakout board and it worked fine. There is a 1 K resistor
that I soldered to the end of the red wire. This protects the LED
inside the photointerruptor from seeing too much current. If you
don`t include the resistor the LED will burn out.
Old 04-30-2005, 05:00 PM
Smile photo limits
is that power to the + and - and the switch is between the out to -
Don C
Old 04-30-2005, 05:56 PM
Gold Member
photointerruptor
Hi Don C
I don`t understand your question. Here is a doc
that shows the pin layout of the photointerruptor.
http://rocky.digikey.com/WebLib/Shar...ta/gp1s73p.pdf
Old 04-30-2005, 06:18 PM
Angry photo limits
I got the limit to work but backwards. Im using a pmdx breakout board and I have the limit connected to +5 -5 and pin 11. I'm using Mach2 and it enables my drive (XYZ)axis only when you put something infront of the limit. and I only have it connected to x+
Old 04-30-2005, 06:46 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
go into your limits configuration and change the "active high/low" setting...then try.
Old 04-30-2005, 06:47 PM
Gold Member
limits
Hi
I could be wrong on this point. I think Mach2 allows
you to configure a high or low for the limit. It might
be possible for you to make this work from the Mach2
software.
  #11   Ban this user!
Old 04-30-2005, 08:35 PM
photo limits
under conf. there isn't limits. Under ports and pins there is but no active high low setting that I can see. and it shuts all axis down and I only have x++ checked.
Don
Carving A Portrait In Wood Using A Photo ljoe1969 DIY-CNC Router Table Machines 12 10-08-2009 11:09 AM
Can I go from photo to gcode? SCCoupe General CAM Discussion 3 03-06-2005 03:41 PM
Limit Switches Mr.Chips Xylotex 7 02-24-2004 09:13 PM
Photo Gallery CNCadmin CNCzone Club House 0 11-27-2003 01:01 AM
Limits, homing, and relay switches Bloy2004 General Electronics Discussion 3 11-24-2003 05:17 PM
