urgent! Help Hi, Ive designed a circuit which is a PIC18F4550 based. which uses SDCard, USB , Key Buttons, Piezoelectric Speaker, and drives 7 Stepper motors.. It might have errors in it.. I need to Design PCB board immeditely.. It would be very helpfull if the errors are spoted.. Pls Help.. I've attached the Circuit here.. |
| Hi Samuel, It looks like your stepper motors can only spin in 1 direction... Is it what you want? Also, check RA4. I think it not a TTL output level... It may requiere a pull up or something. You may need a faster crystal (To run USB 2) if you run the motors a bit fast or in complex movement. (Have a look at the PIC datasheet for the list of crystal supported) Have you got any USB coding experience? Because it is a bit complicated if you start from scrach... Hope this help, RNR |
Ya want it all to apin in 1 direction.. I checked RA4.. I'm having problem as u said.. But i do not Know how to do it,( USE PULL UP or Something).. Can u help.. and abt USB, I'm using MikroC's LIB.. SO no much problem with it.. |
| Samuel, I had a quick look at the datasheet, you should not tneed any pul ups... But you need to make sure you clear all the bits of the TRIS_A register. By default some of the pins of port A are set to input. And RA4 is share function with USB (When using external USB device) and with Timer0 input trigger. Make sure use declare and specify the use of Internal USB device. And do you use Timer0 in your code? What is "MikroC's LIB" ? Do you mean Microchip? what compiler are you using? RNR |
| Need Help!- Check if my Circuit is right.PIC18F4550- USB, Stepper Motor, keypad & SD-Card.. | Samuel Onesimus | PicStep Controllers | 7 | 12-14-2010 07:45 AM |
| please check if my settings is correct | 15mgtar | Stepper Motors and Drives | 1 | 10-02-2009 11:29 AM |
| Spell check it out!!! I just noticed CNCzone now has spell check! | HayTay | CNCzone Club House | 3 | 01-19-2007 07:59 AM |
| Someone Please Check MY circuit | Mr.Chips | Xylotex | 6 | 10-21-2006 10:42 AM |
| correct pallet check | kmuller | General Metal Working Machines | 0 | 01-14-2004 03:54 PM |
