Old 04-27-2005, 03:01 PM
The Wizard's Avatar
The Wizard is on a distinguished road
Canadian sources for transformers?
Hi folks,
I am building a variation of JGRO's router (build log here... http://cnczone.com/forums/showthread.php?t=6244) and I recently decided I had to upgrade the board/motor set up I had as I was just not getting the speed I needed to use the machine. I decided to go with the major 3 axis package from Hobby CNC with the intention of running it at a higher voltage than my current computer power supply. This package comes with all the parts for a suitable power supply except for the transformer.
I have tried to source a suitable transformer within Canada to try and avoid the border taxes (I got hit for $50 on the package when it crossed the border) as I am medically disabled and on a very fixed income. I have tried online and scoured the local yellow pages but the only place I found was an electrical distributor in the nearest city (Windsor, ON) who could order in the recommended Hammond transformer at a cost of $80+ CDN plus taxes (ouch!).
Can anyone recommend a source for suitable power transformers (either new or surplus) within Canada? The specs call for 30VAC at 10A (300VA?) as the ideal size but 24VAC at 10A (240VA?) will do the job too.
Any help will be greatfully appreciated .
Larry
Old 04-27-2005, 04:33 PM
Al_The_Man's Avatar
Plitron Is a Canadian company.
Also is Hammond available through Electrosonic and others.
Al
Old 04-27-2005, 05:20 PM
The Wizard's Avatar
Al
Thanks for those Al. Plitron has no prices on the site unfortunately so I will have to call them tomorrow. The Hammond is available through Electrosonic but is virtually the same price as my local Electrozad Supply branch so by the time you factor in shipping I would be better off buying locally. The roughly $80 price tag is amazing for a transformer (I guess I am out of touch with current prices).
Just for info the Hammond transformer recommended is Part #165S30.
Larry
Old 04-30-2005, 09:36 PM
wildebs_27 is on a distinguished road
You can also get transformers from these sites :
http://www.active-tech.ca
http://www.addison-electronique.com/
I'm getting most of the parts I need from them. Addison is more or less an electronic surplus depot, if it's not on their catalog, they probably have it in stock bu you need to call.
Try those ! I know Active got Hammond Mfg transformers.
Old 04-30-2005, 10:59 PM
The Wizard's Avatar
Thanks for the links I will check them out.
Larry
canadian supplier threaded rod? rickkun DIY-CNC Router Table Machines 4 02-12-2006 11:50 AM
Power Supply Sources Sanghera General Electronics Discussion 22 09-27-2005 10:43 PM
Need MT3 collets, opinions or other sources? jester69 General Metal Working Machines 5 05-18-2005 10:02 AM
How about a list of sources for Linear slides? fyffe555 DIY-CNC Router Table Machines 18 03-29-2005 12:52 AM
Sources for ingots ChrisJ Casting Metals 5 01-24-2005 06:18 AM
