Old 03-19-2010, 11:49 AM
slavkok is on a distinguished road
Simple EPP IO board
Hello...
As my machine happily run under EMC and parport driver now I'm runing out of pins.
Currently I have 3x3 pins to control 3 steppers (custom design with strange 3 wire interface) based on linisteper. Work perfect in halfstep/full torq with my 3V 3A steppers. It has power save function too (after 1 sec no moving the current is halved). Next I have spindle output relay with chargepump and chargepump enable all signal. Few limit and home switches and there are no free pins left. .. and as I use laptop there is no way to add another lpt. And of course all things is opticaly isolated from pc.
So as I want to extend this to one more motors (like to have two bipod for foam cutter) I'm in stage of designing board. For now I'm planed.
4 relays 10A/240V AC (all 4 operates as chargepump so false triger is not likely)
20 Digital outputs can be extended (up to 72 is possible but that's owerkill for software stepgen)
16 Digital input's can be extended (up to 80 but that's too is overkill for software stepgen)
EPP interface side opticaly isolated from other components. (20 cheap optocoupler's needed instead at least 32 if output side is isolated)
Material cost should be under 25Euro.
The board has only digital logic. No PLD's No CPU's Just Optocouplers 74HC4017, 74HC00, 74HC14,74HC573 and few discrete components.
Someone interested?
Slavko.
p.s.
I don't want to sell. When done all design will be posted on forum for free.
This is cross post from http://tinyurl.com/yj3zru9
Old 04-09-2011, 07:11 AM
deny_jae is on a distinguished road
sir...do you have a list of material (bom)?
please send me....
Old 04-09-2011, 07:31 AM
I do not have BOM
But can be obtained from schematic.
The problem is that board as is doesn't work. I think that 4 wires are incorrect and I changed that in my board and doesn't draw corrections. ..and then the working board is sold and I have a lot of other job to do.
I do only one of that board as for other stuff i had just enought port pins.
Maybe Is worth to make one board for 8 (or 16) in and 16 out. That cover near all hoby machines. I wil do that if I need to do.
Simple Calculations for a simple mind. cr8zy1van Mechanical Calculations/Engineering Design 3 11-04-2009 03:12 PM
Need Help!- Simple Step SSXYMicro Board - how to use with Linux software scriptster Controller & Computer Solutions 0 03-10-2009 12:31 AM
How to connect ELM Board and OSMC Board ? bigeye3107 Open Source Controller Boards 2 06-16-2008 06:26 AM
Please Help!! Simple 3-D part not so simple for me eaglegage Mastercam 16 05-15-2008 10:00 AM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
