Old 03-17-2010, 02:27 AM
Brenck is on a distinguished road
Microstepping Precision
Hi all,
Does any one have a good reading about microstepping accuracy? I mean if you use lets say 1/8 microstepping is it more precise then if you use 1/64? I'm speaking about the degree positioning accuracy, all stepper motors have like 5% step accuracy, is that for full step? What that actually means?
I've read threads that people say that stepper has better repeatability then servos due to the fact that the magnets actually always lock up in the ''same'' place, but still servos make a more precise movement due to the fact of closed loop and it can catch up if something goes wrong. Is that considering a stepper running on fullstep or it doesnt matter how many steps?
Thank you,
Gustavo
Old 03-17-2010, 10:25 AM
packrat is on a distinguished road
You can put encoders on stepper motors also, to run closed loop.
cary
Old 03-17-2010, 12:13 PM
irving2008 is on a distinguished road
Originally Posted by Brenck View Post
Hi all,
Thank you,
Gustavo
Only full (or arguably 1/2) step is accurate to the positioning accuracy quoted - for a 200step motor thats 1.8deg +/-5% i.e. the angular change per step could vary by as much as +/-0.1degree but over a full revolution it evens out.
Microsteps are achieved by balancing the current in the phase coils to hold the rotor partway between step positions. At best this is an approximation and should not be relied on for accuracy - it is severely affected by the torque load on the motor. Microstepping is there for smoothness of movement not to enhance resolution. If you want improved resolution, more than achieved by 1/2 stepping, use a finer pitch screw or gear the motor down.
If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
Tags
accuracy, microstepping, precision, repeatability
Need Help!- microstepping board logix Open Source Controller Boards 10 10-21-2010 05:18 PM
Microstepping and precision ? Mkroe Stepper Motors and Drives 8 12-28-2009 04:49 PM
Microstepping? barkster Stepper Motors and Drives 1 05-16-2007 11:27 AM
New pic for microstepping ajv2803959 Open Source Controller Boards 5 03-21-2005 11:59 PM
precision servos (digital) vs. precision stepper (<3.6degree step angle) bennyben Servo Motors and Drives 6 03-05-2004 10:11 PM
