Old 04-26-2005, 11:31 AM
itsme's Avatar
itsme is on a distinguished road
Limit switches
Hi there,
At last I think I've figured out exactly how limit switches are set up with pull-up resistors etc. All I need now is to find out what kind of switches everyone uses. I'd quite like something that is normally closed and is opened when the table reaches its limit (good for safety if a wire breaks etc...).
Does anyone know of good, cheap switches that would do this job? I've seen some 'proper' limit switches, but at over £10 a piece, I thought that was a bit steep.
Finally, would it make sense to have 2 switches per axis that are wired in series, and then the three axes (or 3 sets of 2 switches) wired in parallel?
Warren
Old 04-26-2005, 04:43 PM
Bubba's Avatar
Bubba is on a distinguished road
Itsme,
Don't know what kind of machine you are using, but if it has coolant, make sure they will not get contaminated by coolant.
On my mill/drill, I use "AAP minature Din limit switches" which I get from Automation Direct here in the states, but feel sure they are available on your side of the pond. I get them for 12 USD ea.
I use one on the X, and one on the Y axis, for the Z axis, I use micro switches as they are out of the path of coolant.
for a fine precision, I am also using optical switches. All are setup as NC (and where necessary, are in series).
Hope this helps.
Art
Old 04-26-2005, 06:01 PM
10bulls's Avatar
10bulls is on a distinguished road
http://uk.farnell.com/jsp/endecaSear...=gensearch&y=0
Old 04-27-2005, 02:53 AM
itsme's Avatar
Hi there,
The machine is a Sieg X1. It's not going to have coolant to start with, but I'm planning on adding it at some stage.
I think I might just go with microswitches to start off with, simply because of the price. When the time comes, I will get some 'decent' switches that can handle the coolant etc. I think I will use 2 switches per axis and will definitely go with NC.
Thanks for the help.
Warren
Old 05-01-2005, 04:50 PM
pauls is on a distinguished road
I'm new to limit switches. I've got several micro switches-Radio Shack- but no info on what terminal is what. These are roller lever switches with 3 solder pins labelled 1,2,3. What's positive, ground? How to wire?
Old 05-01-2005, 05:02 PM
da21 is on a distinguished road
you will find the microswitch is a single pole changeover (spco)
i.e one pin is common and switches ( toggles ) between the other two depending if the lever is depressed or not
if you have a multimeter set on restance it's easy to find which is the common
Help with limit switches and Xylotex board dowling177 Xylotex 5 11-26-2008 02:51 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
Solid state limit switches Swede General Electronics Discussion 0 01-03-2004 06:22 PM
