Old 03-08-2010, 12:13 PM
brutto is on a distinguished road
what is the deal about midband resonance damping?
hi all,
could anyone tells me about what is the deal about midband resonance damping? i means, when i gets the frequency where the motor is in the resonance zone (midband), what must be done? limit voltaje (i think the resonance comes and the voltaje is going up), change frecuency (motor is in it's natural frequency zone), add in a coil the angle lossed in the other coil?
i have read some threads about midband resonance but noone says what must be done, only says about you can add an antiresonance circuit or add an algorithm to the gates, but what must be done in the effect? (electric effect, not mechanical like change inertia rotor).
thanx in advance and sorry my english.
Old 03-08-2010, 04:00 PM
ger21's Avatar
If your steppers are dual shaft, adding dampers is very easy and works great.
http://www.cnczone.com/forums/showth...639#post256639
Old 03-10-2010, 11:07 AM
hi, i would to know about electronic midband damping.
Midband resonance compensation sp1nm0nkey General Electronics Discussion 1 06-17-2009 10:19 PM
Gecko 340 limit,gain,damping zero position? Preston E Gecko Drives 1 05-07-2008 03:10 PM
Gain, Damping, Limit THend Gecko Drives 1 04-10-2008 03:17 PM
Vibration Damping Geof Mechanical Calculations/Engineering Design 3 11-08-2007 02:44 PM
How does midband resonance suppression work? phantomcow2 General Electronics Discussion 14 02-21-2007 10:54 AM
