Page 1 of 16 123411 ... LastLast
Results 1 to 12 of 188
Thread: What Power Supply?
    Registered JavaDog's Avatar
    Mar 2004
    What Power Supply?
    Ok, as I am getting into the construction phaser of my CNC router - I have been putting off this part.
    I am using Gecko G320s and Servos from Jeff @ HomeCNC. I need to find a powersupply that will work with this set-up. Sadly, I am not savvy enough to build my own. So, any help/recommendations would be greatly appreciated!
    Here are the specs on my Servos:
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Jan 2005
    Missouri
    Building one is not hard at all.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Aug 2004
    Darn those are "pee wee" servos......so 36 VDC at 3 amps for each......so what you need is a 36 VDC power supply with a 10 amp rating and surge capability of double that......can you wire stuff?
    Mar 2004
    Quote Originally Posted by ViperTX
    What do you mean?
    Jeff that sold me the servos also sent a PDF with some schematics for making a power-supply. It looks pretty straight-forward, but I'm only used to working with DC...
    Aug 2004
    JavaDog....well the only problem with working with AC is to wire the Line and Neutral correctly to your AC power switch. I suspect that Jeff sent you a schematic of a power supply built with a toroidal transformer?
    Registered DieGuy's Avatar
    Apr 2005
    JavaDog they are dead easy, Have a look at the whitepaper @ gecko site.
    Mar 2004
    Yes, I believe so. I would post the diagram he sent, but it is something he includes with his auctions - so I don't want to post it unless he says OK.
    Quote Originally Posted by DieGuy
    I'll take a look.
    So, where does one source a toroidal transformer? How do I know what one is the right one?
    Aug 2004
    Toroid search on ebay.....you'll need something in the 25 to 27 VAC Secondary at 15 to 20 amps.
    Apr 2005
    Here is a link to the PILTRON rating tables. Got no idea on price for these YET!
    http://www.plitron.com/pages/Products/Std/ratings.htm
    Jan 2005
    Missouri
    If you click on "order" then "prices" you will find everything needed. For a 625 va and 750 va torroid you are looking at almost $100. -OUCH-
    Maybe I'm too much of a tightwad, I would rather find a surplus one and rewind it.
    Gold Member
    Dec 2004
    Newtown, CT, USA
    I got my 1200VA toroid from: http://www.avellindberg.com
    Plitron wanted $112 dollars for the toroid that I got from avel lindberg for around $80.
    Plitron also quoted 4-5 week delivery -- Avel Lindberg had it in stock. I also saved shipping because they are here in Connecticut.
    Just a happy customer.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    Javadog,
    For my transformer, I re-wound the secondary of a microwave and it does just fine. You will find a "how to" on the Zone at:
    http://www.cnczone.com/modules.php?n...warticle&id=27
    Easy to do and cheap
    Art
  • Page 1 of 16 123411 ... LastLast
    1. How does a power supply work.
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 07-27-2011, 10:40 AM
    2. Diy Power Supply Choices
      By berin in forum DIY CNC Router Table Machines
      Last Post: 07-13-2005, 04:47 PM
    3. 5 Volt Power Supply Tripping
      By murphy625 in forum General Electronics Discussion
      Last Post: 02-27-2005, 10:05 PM
    4. Is this power supply rating adequate?
      By jerryrigge in forum General Electronics Discussion
      Last Post: 11-25-2004, 11:06 AM
    5. Choosing a Power Supply for Retrofit?
      By pfeist in forum General Metal Working Machines
      Last Post: 05-23-2004, 11:36 PM
