Old 03-06-2010, 11:17 AM
karl1's Avatar
karl1 is on a distinguished road
Mesa 5i20 PCI card
Help! I wanted to try to use the SoftDMC firmware portion of my Mesa 5i20 card. The problem is that I cannot find anywhere in the manuals, website or Googling, a description as to how to interface with the firmware. The manual describes where the bits fall in sequence and the commands needed to manipulate bits, but I am lost as to "talk" to the firmware. Am I missing something? I was assuming that once the card was recognised in the computer, one could use a software program to poke around, and check/set bits. Am I missing this software? I can't believe that there isn't a step by step instructions as to how this can be done. Currently I am using a Linux PC, but willing to move the card to a Windows PC if needed. I had this card running with EMC2 2.3.5 and a Mesa 7i33 Quad Servo Driver card. I was trying to get the Mesa 7i39 card to run (plug and play) but I was informed that EMC2 doesn't support this card. It would be nice to get my motors to turn soon; As a non-programmer, I was trying anything. Ultimately, I need a firmware configuration that will, under EMC2, drive a Mesa 7I39, but the HostMot2 driver would most likely need reworked to support the three phase PWM generator module; and I would probably be need a HAL component to generate the proper drive sequence for the 3 phase BLDC servo motor.
Any guidance would be appreciated.
Thanks!
Karl
Anyone with Mesa 5I20 and 7I33 stories? karl1 LinuxCNC (formerly EMC2) 15 12-13-2008 11:28 PM
Mesa 5i20 + Boot Up Sequence TZak LinuxCNC (formerly EMC2) 2 12-10-2008 11:55 PM
Spindle Encoder to Mesa 5i20 RogerN LinuxCNC (formerly EMC2) 3 10-17-2008 07:55 AM
HELP to Setup - Mesa 5I20 + Joypad.hal - TZak LinuxCNC (formerly EMC2) 0 02-02-2008 04:43 PM
Mesa 5i20 and EMC daedalus LinuxCNC (formerly EMC2) 6 06-27-2007 02:19 PM
