Old 04-21-2005, 08:13 PM
trubleshtr is on a distinguished road
torodial output seems odd
I just put 120vac into my torodial.
got 45 vac out of it
put that onto rectifier, got 40Vdc out of rectifier??
Does this seem right?
I thought this was the math to ball park the output of the rectifier.
45vac out of torodial x 1.414 = 63.63 volts dc from rectifier?
can someone explain this to me please.
menomana
Old 04-21-2005, 08:19 PM
Al_The_Man's Avatar
The 1.414 multilplier only applies to a capacitive smoothed supply, in other words if you are measuring just AC ripple after the bridge, you are now measuring the RMS of a 120Hz ripple, put an electrolytic cap on the bridge output and you will now read the peak, which is RMS x 1.414 less voltage drop for the rectifiers.
Al
Old 04-21-2005, 08:22 PM
Thanks Al.
So would that be 40 vdc x 1.414
or
45 vac x 1.414
after I place the caps in the loop?
menomana
Old 04-21-2005, 08:42 PM
Al_The_Man's Avatar
Your DC should read approx (45x1.414)-2 . The -2 is to allow volt drop for the two diodes.
Al
I need to build a paper tape emulator paramax55 General Electronics Discussion 14 04-11-2007 04:40 PM
Pro/manufacture -number of decimal places arc events dsergison Post Processor Files 4 05-27-2005 12:50 PM
8830 Line driver for encoder output? murphy625 CamSoft Products 4 03-29-2005 01:15 PM
Dirction / Step lines! bigal TurboCNC 2 02-06-2005 01:51 PM
Power Supply, Output Sanghera General Electronics Discussion 6 05-31-2004 12:44 AM
