Old 04-20-2005, 08:08 PM
juxtoposed is on a distinguished road
Have 3 caps, which one to use?
I have a 34 volt 21 amp transformer and I have three caps but don't know which would be "best" to use.
1 16000 MFD 75 VDC surge 95 VDC
2 18000 MFD 75 VDC surge 95 VDC
3 25000 MFD 50 VDC surge 75 VDC
Any help would be good.
Thank you
Old 04-20-2005, 08:38 PM
Al_The_Man's Avatar
For 2.5% ripple at that voltage (~46vdc) and 21amp current you would require a 53,000µfd
25,000µfd would result in 5.5% ripple.
Al
Old 04-20-2005, 08:39 PM
Sorry it is actually a 24 volt transformer. How does that change things?
Old 04-20-2005, 08:50 PM
Also could I use more than one of the caps to reach that rating?
Old 04-20-2005, 09:28 PM
Al_The_Man's Avatar
The new numbers at 24vac would be for 5.5% ripple = 35,000µfd at 2.5% ripple = 77,000µfd.
Al
Old 04-21-2005, 10:33 AM
ViperTX is on a distinguished road
Yes, parallel the first two capacitors....don't forget your diode bridge. If you need more capacitance you can parallel the third one.
Old 04-21-2005, 12:43 PM
*Registered*
ESjaavik is on a distinguished road
When you place them in parallel you just add the capacitance. 59000uF for all of them in parallel. (I assume you mean uF, as a 25000 Mega-Farad capacitor will be quite big!)
The max voltage is determined by the lowest one (50V).
Series connecting PS caps? jevs General Electronics Discussion 7 03-27-2005 10:20 PM
Caps Installed Wrong Please HELP jockey General Electronics Discussion 6 02-27-2005 10:48 AM
resistor choices trubleshtr General Electronics Discussion 28 01-06-2005 06:55 PM
Crank bearing girdle an0n General Metalwork Discussion 7 11-08-2004 03:10 AM
PSU & CAPs & Motor Questions.. TTaki Gecko Drives 0 11-02-2004 09:43 PM
