Page 3 of 3 FirstFirst 123
Results 25 to 33 of 33
Thread: Charmilles Robofil 200 startup
  1. #25
    Dec 2011
    china
    Smile hello
    MY ROBOFIL 400 Display E672 NO AXIS References in set up system disks.how can anybody help me?
    How to clean the liner encoder of U or V axis? thanks!
    Thanks[/QUOTE]
  2. #26
    Feb 2011
    Iran
    NO AXIS Reference
    Quote Originally Posted by redflower View Post
    [/QUOTE]
    hello
    you do not need to clean the liner encoder !!! it's not safe work you want to do.
    Just do this work:
    1-go on Setup page.
    2-go on Refrence page.
    in Reference page you will see 5 axis X-Y-Z-U-V
    your U and V axis alarmed with a star single near each axis that lose Refrence
    just move u axis to end and go back very slow do this work for V axis, star single will not see and your machine will work correct.
  3. #27
    Dec 2011
    china
    Smile thank you!
    [QUOTE=CNC_Technician;1053314]
    thank you ,cnc_technician;according to your method,the references are ok,but displayed E213:Z,W,or R with tilted wire.that I don't know how to operate it.
    and i need ROBOFIL 200 852478 CCU EXE chip program:978081,978583.thank you very mach.
  4. #28
    Feb 2011
    Iran
    E213:Z,W,or R
    [quote=redflower;1053656]
    Quote Originally Posted by CNC_Technician View Post
    hello
    your are welcome. for E213:Z,W,or R: move u and v axis to zero then start program (iso file). at first u and v axis must be in vertical position and then start. some times this problem is from Gcode file. please try again and told me.thanks.
  • #29
    Dec 2011
    china
    Smile
    [quote=CNC_Technician;1054124]
    hello
    The times are chinese new year.thanks for your help!
  • #30
    Dec 2011
    china
    Smile hello
    [quote=redflower;1056007]
    The quasion is the crash water pump switch was invalidated,and indicator linght don't lighen coinstantaneous,in my robofil 400.how can i do?
  • #31
    Dec 2011
    china
    Smile hello
    I need ROBOFIL 400 POST (robo.pst for mastercam X4 or mastercam 9.1),can anybady help me?email:redflower806@yahoo.com.cn,because when load program(*.iso),displayed:E001 invalid command.thanks!
  • #32
    Dec 2011
    china
    Smile
    how anybody can help me ?
  • #33
    Sep 2012
    India
    Calling subprograms from command files
    Hi
    I have recently purchaced a 1991 Robofil 200. I have not purchaced any software as yet and transfering programs thru serial port.
    Problem is how to call sub programs from command files. I have the manual but it does not have S or G98 functions in which tec can be set and sub programs called. I have written a command program for rough and finish pass. Is it correct:
    TOF,D1,0.299 ; OFFSET FOR E1 FOR HT 8mm
    REX,E1,H8
    SPG,MEM:HEX16; calling program rough cut
    TOF,D2,0.134 ; OFFSET FOR E6 FOR HT 8mm
    REX,E6,H8
    SPG,MEM:HEX16 ; calling program for finish cut
    Does the machine stop after each program.
    Thanks any help will be appreciated
  • Page 3 of 3 FirstFirst 123
    1. Charmilles Robofil Wire Edm
      By sundara in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 10-13-2012, 09:26 AM
    2. CHARMILLES ROBOFIL ALARM/MANUAL
      By SINUMERIKO in forum General Waterjet
      Last Post: 03-29-2011, 02:37 PM
    3. Charmilles Robofil 440 Power Settings?
      By Tool Maker 24 in forum General Waterjet
      Last Post: 09-10-2009, 05:50 AM
    4. Charmilles Robofil 300/310 Door Alarm
      By WIRE CUTTER in forum General Waterjet
      Last Post: 07-25-2009, 07:34 PM
    5. Robofil 510
      By fruivo in forum General Waterjet
      Last Post: 11-16-2007, 11:03 AM
