Page 1 of 43 123411 ... LastLast
Results 1 to 12 of 513
Thread: CNC Oxy/Fuel Discussion
    WSS
    WSS is offline
    Registered WSS's Avatar
    Mar 2009
    U.S.A.
    Cool CNC Oxy/Fuel Discussion
    Here is a thread to post your Oxy/ Fuel cutting questions, ideas, problems and PHOTOS!
    Let"s discuss codes, speed, gases, tips (consumables) or anything concerning oxy cutting.
    And please don't be afraid to call "Dross" slag here. Oxy cutters will know what you are talking about!
    Cheers!
    WSS
    Feb 2006
    I have been looking for a way to ramp up the cutting oxygen, Something like a soft start valve, or........... ?
    I have found Retro plasma makes a regulator assy. with "Ease on pierce rate control ". They describe it as "The rate that cutting oxygen pressure increases during the pierce is
    set by the Pierce Rate Control knob".
    I can't find much info on this type of system on the net.......... Anyone familiar with this type of system?
    May 2003
    Illinois
    Oxy-fuel system
    Gentlemen:
    I have attached (4) jpg's of a system and explanation. Hope it is of help to youall.
    Regards,
    Jack C.
    PS: to print a decent sized page, click on desired page, right click on the result, then "print".
    JCC
    Attached Thumbnails Attached Thumbnails CNC Oxy/Fuel Discussion-january_30_2010.jpg   CNC Oxy/Fuel Discussion-january_30_2010_2_.jpg   CNC Oxy/Fuel Discussion-january_30_2010_3_.jpg   CNC Oxy/Fuel Discussion-january_30_2010_4_.jpg
    Registered millman52's Avatar
    Jan 2006
    USA , West Virginia
    This is interesting. I often have trouble piercing material above 1" thick
    If it works.....Don't fix it!
    Nov 2006
    I am setting up a oxy / fuel cutter. I need all the help I can get.
    Steve
    Jan 2006
    USA , West Virginia
    Steve, have you made any more progress with your port 2 installation to get your system going?
    Nov 2006
    Millman, I talked to Tom, and he said that I have the wrong version of the IO card. So I need to get the correct drivers installed.
    I just finished replacing the 7/8 drive stem pinions with 2 1/4 gears. Now the vibration is gone, I am going to work on the IO card.
    What Post processor is everyone using for Sheetcam?
    Steve
    Feb 2006
    Thank you JCC,
    That is exactly what I have been looking for.
    Steve
    WSS
    WSS is offline
    Mar 2009
    U.S.A.
    I wonder if this could be done with a small bore "oxy safe" air cylinder that has had the piston converted to a plunger and the rod changed to a 1/2-10 acme thread for adjustment? It would serve only one torch for the ramp up oxy. but might be doable. The ramp pierce is pretty handy to keep slag traveling in a rearward or away direction. The Hi PH could be done with a separate set of 3 way Asco type solenoids and a extra set of regulators. Once you found the right combination you could manifold the whole deal to pull from one (of each) bottle.
    I converted the jpgs from jcc3inc's post to a pdf (Big thanks Jack!)
    Here is a link:
    http://files.me.com/izonltd/id43n2
    WSS
    Feb 2006
    "air cylinder that has had the piston converted to a plunger and the rod changed to a 1/2-10 acme thread for adjustment? "
    I'm afraid you lost me on that one!
    Steve
    Jan 2006
    USA , West Virginia
    Quote Originally Posted by scrambled View Post
    Steve
    Steve I had gone to the manuals on CandCNC's Yahoo site & done a bit of reading on installing the MP3000. Somewhere in there it mentioned the version of one of the cards needing to be current. It was yesterday evening when I was reading it & by now I can't remember the details.
    Knowing your project has been a lengthy one just kind of assumed something slightly out of date might be your problem. I'm probably the worlds worst to buy something then let it lay for weeks or months before using it.
    I started building an actuator type "Z" lifter & an new HT 1250 plasma nearly a year ago & still don't have that installed & am paying to have thin materials plasma cut. I can't really say I haven't had the time I just haven't made it happen.
    Tom will get you through it. He has always had the answers I needed. Sometimes I can be shch a bonehead that it takes a week or 2 for what he is telling me to sink in.
    I am using the Mach2 plasma.post for my oxy set up. (again I am running 2006 or so vintage MP1000 candcnc equipment)
    Feb 2006
    Smile
    ...... It just dawned on me what you are describing!
    The air cylinder could be controlled with shop air and it wouldn't need to be oxygen clean.
    I will have to experiment with force requirements to see how big of a cylinder it would take.
    The beauty of this is I have most all the stuff laying around to build it with!
    Thanks for the idea!
    Steve
  • Page 1 of 43 123411 ... LastLast
    1. Need Help!- CNC Oxy Fuel Help
      By Gawker in forum Torchmate
      Last Post: 12-23-2008, 06:43 PM
    2. Problem- Oxy-Fuel Setup
      By Feckless in forum Torchmate
      Last Post: 05-20-2008, 11:19 AM
    3. EPA fuel standards
      By cdlenterprises in forum Environmental & Alternate Energy
      Last Post: 04-16-2007, 08:38 PM
    4. Fuel Injection Manifold
      By BobWarfield in forum Rhino 3D
      Last Post: 12-12-2006, 01:11 AM
    5. Water as fuel...
      By WilliamD in forum CNCzone Club House
      Last Post: 06-16-2006, 06:01 PM
