The problem is that pressure washers and flowjets are two completely different animals. Pressure washers are looking to generate just enough force at the work surface to lightly abrade it, and remove contaminants. A flowjet is punching clean through. Flowjet is high pressure/ low volume; pressure washer is high volume/ (comparatively) low pressure. 100W CO2 laser/ vs. 100W light bulb. Both deliver the same amount of energy, but in completely different ways. Now, you WILL be able to blast your way through things like soft wood, etc. with a powerful enough pressure washer, but to what end? The quality and speed of the result will not justify the cost.
If you are looking to work fairly soft materials, and want speed, your best bet is a high speed spindle. If you want something exotic, look into a good CO2 laser. Thin materials are quickly cut, and the cost of laser systems has been steadily decreasing- you can get a decent turnkey CO2 cutting laser head starting at about $7500 these days. Look at the Synrad 25W system that Torchmate offers. It would probably be sufficient for your application.
LinkBack URL
About LinkBacks
