Originally Posted by
Dave--O
Trying to set up new table, it is used and i have everything working but the thc, i i finally have it identified as a dynatorch technogon, i did not get any documentation with the table, contacted kioke and recieved all the manuals from them, hypertherm 1650 all downloadable but can anyone tell me how to set pierce heigth or plate to tip zero on the thc, when i send to cut, torch comes down fires, starts cut, then plows tip into part as cutting. Also thc seems to over travel on upside till bearings off track and hitting screw coupling. I dont think it should be going this high seems it has lost home point.
Tx
