Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: Euro-Hybrid plasma/router
    Jan 2012
    Limburg
    Hi all,
    I am 29 years old and live in the Netherlands. If my English is bad now you know why.
    I studied Electro-mechanics in Belgium and work in a paper mill as engeneer E&I (electronics & instumentation), in my daily work I have to do with PLCs, VFDs, and (power) electronics.
    , I am now building a real machine.
    I would like to make a hybrid machine. so I can do some plasma cutting but can also do milling.
    Because I like to weld I make my machine Completely out of steel.
    My machine is 1m x 1.5m by bringing up the gantry I can cut pieces that are bigger then my milling area.
    (Because I live in Europe, I work with the metric system)
    I've been a busy few weeks now and am now waiting for parts.
    Maybe someone can give me some advise or perhaps someone else gets inspiered.
    Thanks so far
    Dr. Arc
    I put some pictures to make it more clearer
    [IMG][/IMG]
    Jan 2012
    Limburg
    Registered rexcobey's Avatar
    Sep 2010
    italy and Philippines
    hi i woul like to share my work...
    here is the picture of my gantry....
    Sep 2010
    here also the video hope you like it....
    http://www.youtube.com/watch?v=M5zNxsqYViE]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting parts 1 - YouTube
    http://www.youtube.com/watch?v=2EqUb6uJGDo]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting Part 2 - YouTube
    Jan 2012
    Limburg
    http://www.youtube.com/watch?v=-m_aoWduEXI&feature=plcp]DIY CNC Quick Release Rack and Pinion system - YouTube
    http://www.youtube.com/watch?v=E_FlDinltTs&feature=context-chv] DIY CNC Plasma Rack and Pinion system - YouTube
    Hi rexcobey
    I also use Usbcnc from eding, how did you itegrated the thc into the software?
    The software disigner told me there is not yet an torch up, torch down and arc ok feature like mach3.
    For milling, USBCNC from edding is the best!!!
    Sep 2010
    Quote Originally Posted by Dr. Arc View Post
    Hi rexcobey
    for THC i am using the one made by Agelkom from Turkey, this is stand alone THC
    Sep 2010
    Hi rexcobey
    Also do you know Kevin Damen of Damencnc.com, he is developing THC for this USBCNC of eding, i just waiting for this...
    Jan 2012
    Limburg
    Quote Originally Posted by rexcobey View Post
    I know Kevin, I bought most of the parts there. In januari he told me he was thinking of making a complete system together with Bert Edding.
    because it will be a Hybrid i'll make the milling parts first then i'll ad an plasma function on it.
    On your pictures i see both (router / cutter) on the same Z axle, does it work well?
    I'm thinking of making two Z's. one for cutting and one for milling.
    Sep 2010
    yes i have teknomotor in my z axis i put because i need to make a hole on the plate before execute the plasma or oxygen fuel cutting to bypass the piercing
    procedure.
    on my z axis you can see there is two motor, one on z axis and the one on the torch lifter.
    on my z axis the stepper motor are hookup on my usbcnc CPU5 B while the motor on my torch lifter are hookup on stand alone THC
    Sep 2010
    here is some of the picture
    Attached Thumbnails Attached Thumbnails Euro-Hybrid plasma/router-20120330_145524.jpg   Euro-Hybrid plasma/router-20120330_145533.jpg
    Jan 2012
    Limburg
    Nice pics,
    I use CPU5A4 Economy 4 axes
    but mayby in the future I'll get an upgrade.
    your machine looks very professional, is it just hobby or do you use it commercially?
    Sep 2010
    Nice pics,
    i will use this on my fabrication shop in Philippines, when i'm back there...
  • Page 1 of 2 12 LastLast
    1. Adding Plasma to a CNC Router - Hybrid?
      By Ed3XP in forum Plasma, EDM and other similar machine Project Log
      Last Post: 12-20-2011, 01:56 AM
    2. CNC Router Hybrid Wood/Steel
      By Grandad in forum CNC Wood Router Project Log
      Last Post: 03-25-2009, 08:24 PM
    3. Plans for Joe's Hybrid CNC router?
      By jeffmorris in forum Joes CNC Model 2006
      Last Post: 08-12-2008, 07:05 PM
    4. Is this worth 100 euro?
      By Frost in forum Stepper Motors and Drives
      Last Post: 06-27-2006, 02:53 PM
    5. Euro fitting Machine torch for plasma?
      By hotponyshoes in forum General Waterjet
      Last Post: 03-16-2006, 11:00 AM
